No power from working battery
Started by Paianni, February 22, 2026, 18:28
moredun
My battery pack was 3 x 1.6V giving a total of 4.8 volts compared to your 7.2 volts. Is your MR2 facelift?
Keep us posted if it works for your plz, must be lots of 20+ year old rechargeable batteries coming to end of life.
fawtytoo
Quote from: moredun on March  2, 2026, 21:08My battery pack was 3 x 1.6V giving a total of 4.8 volts compared to your 7.2 volts. Is your MR2 facelift?
Mine is PFL.
Looking again at your pic, you had 6 cells in 3 pairs, - so probably 7.2v
rusty0273
Anyone know if you can simply remove the backup battery pack and rely on the 12v for the alarm siren or will this result in the 16 beeps or alternative nagging from the car? If you remove the siren unit entirely, that could impact insurance cover.
Quote from: rusty0273 on March  3, 2026, 11:57Anyone know if you can simply remove the backup battery pack and rely on the 12v for the alarm siren or will this result in the 16 beeps or alternative nagging from the car? If you remove the siren unit entirely, that could impact insurance cover.
Read Post #24.
rusty0273
Quote from: Gaz mr-s on March  3, 2026, 12:30Read Post #24.
Hi. I've read the thread so understand what the purpose of the backup battery is. My question is whether it can be removed from the siren or will cause issues. moredun removed the whole siren so obviously would not hear any beeps indicating a fault.
moredun
Quote from: rusty0273 on March  3, 2026, 14:14Hi. I've read the thread so understand what the purpose of the backup battery is. My question is whether it can be removed from the siren or will cause issues. moredun removed the whole siren so obviously would not hear any beeps indicating a fault.
As it stands, although no audio  from the alarm, everything seems to work ok. Remember you still have the indicators for visual feedback ie locking and unlocking the car, deadlocks etc. There are no nagging buzzers or led's to indicate a fault with the alarm.
While the siren was off the car, I broke my leg and have been unable to replace the siren without the batteries and test it. Give it a couple of more weeks and I will try it then.
rusty0273
Thanks and wishing you a speedy recovery.
rusty0273
Quote from: fawtytoo on March  1, 2026, 19:12Different battery in mine ...
And that was a bit clumsy of me ...
My battery looks like this one. Did you find a replacement? Searching seems to come up with the alternative '3x2 cell' format rather than our 6x1 versions.
Whatever the shape, it's 6 x 1.2v nicads.  If there is some extra space that will allow the pack to be slightly larger, 6 cells could be bought & soldered together with an adequate iron & thin insulated wire.
There might be packs ready-made for the likes of radio controlled products. Vehicle or transmitters perhaps.
But I'd be checking first if the charging cct works, otherwise there's no point.
rusty0273
Thanks. I can confirm that the alarm still works fine with the rechargable battery removed or disconnected (as long as you have main 12V battery supply obviously). It looks like a 2/3 AAA format and I've had a good look on the web with no luck finding a 6 x 2/3AAA 7.2V pack ready to go.
More likely 'aa' size, although if I remember correctly they aren't named using same terms.
https://ebay.us/m/HbdHEl     Need to check dimensions.   - Size:84*48*18mm
Probably be ok.   Is the charging cct still ok?
rusty0273
I'm probably just going to run mine without the backup battery but for anyone else who's looking, the pack in my car which looks the same as fawtytoo's battery, is approx 60mm x 30mm x 10mm. 6 cells in a line. There is a tray in the sounder designed to fit this size quite precisely (the tray is visible, holding the battery pack in fawtytoo's photo).
Its a GP battery, P/N GP 28AAAM6BML.
Re, the charging cct - not my bag I'm afraid - don't even know what it is, how to identify it or test it.
I've just found these which are listed under an equivalent P/N and could be a direct fit but the connector looks slightly different (ex Hong Kong).
https://www.ebay.co.uk/itm/297991409847
https://www.ebay.co.uk/itm/286572430695
Maybe somebody can take a punt and feedback.
rusty0273
Bit more searching - this looks right, although no dimensions listed. UK seller.
https://www.ebay.co.uk/itm/163226209115
Quote from: rusty0273 on March  6, 2026, 14:28Re, the charging cct - not my bag I'm afraid - don't even know what it is, how to identify it or test it.
Do you have a multi-meter?
rusty0273
Quote from: rusty0273 on March  6, 2026, 15:02Yep, I do.
The battery has two wires.. same plug connections for battery operating the siren, or the car alternator charging the batteries. So put meter across the car plug terminals & (I assume zero volts). Now start the car. If still zero volts that'd suggest it's not working.  If you do see a voltage, post what it is please.
rusty0273
Quote from: Gaz mr-s on March  6, 2026, 17:23The battery has two wires.. same plug connections for battery operating the siren, or the car alternator charging the batteries. So put meter across the car plug terminals & (I assume zero volts). Now start the car. If still zero volts that'd suggest it's not working.  If you do see a voltage, post what it is please.
The sounder is reassembled and back on my car now I'm afraid (absent one battery).
Quote from: rusty0273 on March  6, 2026, 17:44The sounder is reassembled and back on my car now I'm afraid (absent one battery).
Since you value it, do you know about moving it, for more space, but also making it much louder?
rusty0273
Moving it outside of the frunk? Not bothered about that as this is a weekend car, parked in my garage. Moving the sounder is a bit tricky on my car as it has air con.
Quote from: rusty0273 on March  7, 2026, 09:07Moving it outside of the frunk? Not bothered about that as this is a weekend car, parked in my garage. Moving the sounder is a bit tricky on my car as it has air con.
It can move all the way back to the bulkhead.  Cut cable ties to free the loom, & cable ties to fix it. Others will have done different.
Paianni
New battery was fitted 11 days ago, all seems well so far.
Thanks for the advice.
