Engine modifications and performance gains for FI 1ZZ
Started by muffdan, November 25, 2009, 15:19
muffdan
To help better understand the tuning capabilities of the 1ZZ engine, it was decided that members of this forum would post there modifications and the net engine power gains that were achieved, so here goes:
Age of Car
2000 but not original engine
Miles completed
106k - 5k on current engine
Engine Mods
MWR built engine - 1.93l bore out
GT28RS Turbo
MWR Ported Head
Crower Stage II FI cams
Crower Connecting Rods
Wiseco Pistons 8.8:1 compression
Darton Sleeves
MWR valve set
MWR springs
ARP main/head stud kit
2ZZ water pump
Oil cooler + front mounted radiator
630cc injectors
Rising rate fuel pressure reguator
250l/h fuel pump
Induction Mods
Custom 3" intake through to turbo
MAP sensor
MAF (for temp readings) moved post charge cooler/pre throttle body
PWR 5x6 barrel charge cooler
SARD BOV
Exhaust Mods
Custom 2.5" free flowing exhaust with quad exit tail pipes.
Engine Electronics
Link G4 Storm replacement ECU
Iridium spark plugs
Link Knock Block
Innovate AFR kit with Bosch sensor
Mapping
Yes – Thor Racing
Performance
Low Boost  (15.5psi)
~293.0 BHP
261.8 Lb Ft at 3861 RPM
7000 rev limit
High Boost  (18.5psi)
~320.0 BHP
286.3 Lb Ft at 3870 RPM
7000 rev limit
Here is the final mapping results from Thor.
Age of Car
2004
Miles completed
Currently 33k, about 22K on install
Engine Mods
PPE turbo
Oil cooler + side vent mounted radiator
330cc injectors
Induction Mods
?? CAI
?? charge cooler
?? BOV
Exhaust Mods
SP exhaust with std cat
Engine Electronics
Emanage
Copper (cold) spark plugs
Innovate AFR kit
Mapping
Yes – Hypersports
Performance
Boost restricted to 5 psi
220.5 BHP.
No torque, but early map at 210 bhp showed 190 ft lbs
Here is the final mapping results from Hypersport.
JudoKilli
Would it be possible to add the amount spent to get each car to where it is now? Just so that members can scope the possible range of improvements based on price.   s:D :D s:D
Quote from: "JudoKilli"Would it be possible to add the amount spent to get each car to where it is now? Just so that members can scope the possible range of improvements based on price.   s:D :D s:D
I'll pass on that one - between me and my chequebook. If anybody wants to though, feel free,
stargazer30
Age of Car
2005
Miles completed
Currently 20k, 20K on install
Engine Mods
SP turbo conversion (low power version)
420cc injectors
upgraded spark plugs
Induction Mods
Cone style induction
Intercooler
BOV
Exhaust Mods
Cobra twin exit exhaust
Engine Electronics
Unichip Q
Mapping
Yes
Uprated clutch
Performance
201 BHP.
185 ft lbs torque
Graph
Mike_V
Age of car
2000
Miles
70K
Engine Mods
Stage 2 SP (GT28) Turbo
550cc injectors
Upgraded spark plugs
Moroso sump
Induction Mods
Custom air induction kit with cone filter
PWR 6X5 custom charge cooler with alloy radiator
Exhaust mods
Custom 21/2" exhaust exiting by number plate, no CAT at the moment
Engine electronics
Link Storm G4 ECU
Electronic boost control
Mapping
Redline Tuning
Helix motorsport clutch
Performance
Currently showing 259.1 BHP
235 lb ft (approx)
2004 Red edition in Sable.
PRspyder
Re: Engine modifications and performance gains for FI 1ZZ
Age of car
2001
Miles
60K
Engine Mods
GT3076 turbo
630cc injectors
2zz water pump
speed source engine mounts
wiseco 8:8:1 pistons
crower rods
MWR pulleys
custom fuel rail
aeromotive fuel regulator
walbro 255 fuel pump
Induction Mods
precision turbo intercooler
Exhaust mods
Custom 3" dynomax exhaust
Engine electronics
Apex power FC
greddy E01
Mapping
Redliner9K (gustavo)
act stage 3 clutch
obx lsd
Performance
Currently showing 297whp
246 lb ft tq
last graph
best pass yet
01 MR-S 25psi 403whp 317TQ GT3076,best pass yet 11.8@121
06 civic Si full k24a2 238whp 192tq DD
MrT
Anyone got some recent info on this? How much boost can a 1zz take without any internals or head mods? Usual intake and exhaust freed up with forced induction of course.
I see Mike_V gets ~260bhp and ~235lb.ft on a stock motor but not sure what ratings that motor is tuned to. Seem like very large injectors being used also.
I'd like to get ~200whp which looks like 240bhp and more importantly I'd like a flat spread of ~200lb.ft torques. Is this reasonable and achievable on a budget?
Tyler
Gaz2405
Thought I'd stick one of these up as there doesn't seem to be much recent info.
Age of Car
2004
Miles completed
100k
Engine Mods
Standard 1zz Block and Head.
TD04 15t Turbo from SAAB 93 Turbo
Oil cooler mounted in drivers side air duct
630cc injectors
Ebay Charge Cooler with 3" Induction piping
2.5" Downpipe straight into Malian sports cat and into TTE Exhaust
Running 10 psi on stock waste gate pressure
Engine Electronics
Apexi PFC
Self Mapped on the Road
Iridium spark plugs 1 setting colder
Performance
10 psi
233.0 Bhp
lancs_lad
No posts for a while, so I thought I'd throw mine on here :
Age of Car
2005 SMT
Miles
31k on car, 3k on build
Engine
Stock 1zz block and heads with 31k miles.
CC 3.9kg lightened flywheel
Exedy stage 2 clutch
Stew's special SMT fluid!
Stock fuel pump and regulator
Turbo Mods
Homebrew turbo system comprising :
Mamba GTX2860RS Billet BB .60 .64 Nissan SR20DET style with Stage 3 actuator. 6psi spring.
Malian turbo exh manifold, catless downpipe and single exit 2.5" system (all off the shelf).
HomeBrew w/a chargecooler - eBay radiator, bosch pump, eBay 5x8 barrel cooler. 12" Mishimoto fan.
440 DW Injectors.
MAC 3 port boost control solenoid.
Custom intake, breather system and cone filter.
Electronics
AEM EMS4 with full closed loop O2 control, boost control, knock control. Twin boost settings.
MWR EMS4 SMT harness (extensively modified! ;-) )
AEM AFR Gauge with 4.9 Bosch WB.
Innovate Oil temp / Pressure gauge
AEM Boost Gauge.
Bosch AIT sensor. Factory MAF and AIT also retained for TCU shift calculation.
Specs
247 WHP at 6250, 261Lb Ft at 3300. >225lb ft 3-6.5k
11-13Psi dependent on RPM (high boost)
10Psi flat (low boost)
7400 RPM Redline.
Stock internals seem fine at 260Lb Ft. Map and cam advance optimised for torque whilst keeping injectors at/below 85% duty.
We did one run at 95% duty - 316BHP / 275 Lb Ft! Don't think it would have lasted long at that sort of output.
Mapping by Wayne at Chipwizards in Rossendale.
