I'm sure this has been mentioned before many times. Some of you have drilled holes to help this problem. Can anyone point me to a "How to guide". With all the very moist weather we've been experiencing, Foxy's behind needs a little tlc s:D :D s:D Thanks,
I cured this by;
removing the light unit;
carefully removing the plastic lens;
cleaning out all the condensation;
Removing the rubber bead / seal that runs all the way round;
Cleaning the rubber seal and the channel it sits in;
Carefully reassembling with a small amount of silicone sealant on both sides of the rubber seal.
The rubber seal on mine had green stuff growing in it which meant moisture could then pass through. I did this around May and they have been totally dry since.
I didn't take any pictures, but it's a fairly simple and logical process to follow.
Personally, I wouldn't drill holes anywhere as it isn't necessary and could lead to further problems.
Thank you, I'm not sure I would be very good with a drill anyway s:lol: :lol: s:lol: I'll wait for the warmer weather and give this a go, thanks. s:D :D s:D
