The Academy => Reference => Topic started by: Carolyn on October 24, 2022, 11:04
Title: Fluid capacities
Post by: Carolyn on October 24, 2022, 11:04
Facelift and pre-facelft cars are slightly different.
Engine oil: 3.7 Ltr
Coolant: 10.4 Ltr
Gearbox: PFL: 1.9 Ltr  FL: 2.1 LTR
Power steering fluid: .65 Ltr,  but to do a proper flush you'll need 2 Ltr
Title: Re: Fluid capacities
Post by: Joesson on October 24, 2022, 13:11
Not exactly intuitive to my mind. The FL has an extra cog, taking up volume compared to the PFL, so why the need for more oil ?
PS
Especially as overfilling is considered unwise.
Post by: Ardent on October 24, 2022, 15:06
If filled correctly via the side fill hole. Cannot over fill. When if runs out. Your done.
OK you could overfill, but would have to be a deliberate effort to do so.
Post by: Joesson on October 24, 2022, 15:33
Quote from: Ardent on October 24, 2022, 15:06If filled correctly via the side fill hole. Cannot over fill. When if runs out. Your done.
But that redundant "plug" on top of the gear box is so tempting for some I guess!
Post by: Carolyn on October 25, 2022, 11:25
PS
That extra cog results in a physically bigger gearbox casing.
Post by: Joesson on October 25, 2022, 12:05
Quote from: Carolyn on October 25, 2022, 11:25That extra cog results in a physically bigger gearbox casing.
That would explain it, thank you. It raised a question in my mind as I understood the gear boxes to be interchangeable. All hypothetical to me though.
Post by: Gibla on February 25, 2023, 09:25
Considering doing brake n clutch fluid replacement ....any clues to capacity, so I order the correct amount?
Post by: Ardent on February 25, 2023, 10:21
Had a look through what bits of info I have. And cannot find a volume.
What type etc. But not how much.
If a normal bleed through. Be surprised if need more than a litre.
Post by: Carolyn on February 25, 2023, 10:21
Quote from: Gibla on February 25, 2023, 09:25Considering doing brake n clutch fluid replacement ....any clues to capacity, so I order the correct amount?
A litre will be sufficient.
Post by: Alex Knight on July 5, 2023, 15:17
Quote from: Carolyn on February 25, 2023, 10:21A litre will be sufficient.
I'm doing brake and clutch fluid soon too.
@Carolyn do you mean 1 litre is sufficient for the braking circuit AND the clutch line?
Post by: Carolyn on July 5, 2023, 15:29
Quote from: Alex Knight on July  5, 2023, 15:17I'm doing brake and clutch fluid soon too.
Yes.
Post by: Alex Knight on July 5, 2023, 15:33
Quote from: Carolyn on July  5, 2023, 15:29Yes.
Thank you kindly.
Post by: Joesson on July 5, 2023, 16:13
Quote from: Alex Knight on July  5, 2023, 15:33Thank you kindly.
I suggest it prudent to do the brake circuit completely first and use what is left to do the clutch
Post by: Alex Knight on July 5, 2023, 23:19
Quote from: Joesson on July  5, 2023, 16:13I suggest it prudent to do the brake circuit completely first and use what is left to do the clutch
Agreed.
I'm getting two litres, to have one for next time I change it.
