hi has anybody got diagram for information , how to install Power Up window thank you James
How do you mean install it?
Or are you just after schematics for the electrics?
If so, register (for free) on Toyota's own technical site.
https://www.toyota-tech.eu/Registration.aspx
Once you're registered, you can purchase access for as long as you need to ALL of the technical schematics.
https://www.toyota-tech.eu/OnlineSubscriptions.aspx
3 quid gets you an hour of all you can eat content. Which is downloadable... How long you can keep it for. Is dodgy territory but interpret that as you want.
Link to wiring diagrams is, after you've bought a subscription:
https://www.toyota-tech.eu/euro5search/index?PUBTYPE=EWD
You just need to pick the car
As I remember there is no easy win to do this. The auto function on the drivers is controlled by the body controller. It's not just a case of installing a switch.
Quote from: StuC on June 7, 2019, 17:05
This is true. Its because it links in with the immobiliser/key fob
That's another difference with the MR S! Didn't know about this one. My body controller fuse is out - no beepers. BUT the auto window function still works.
hi thank you for your help I've got the power up kit , I heard that wire goes to the passenger switch in centre console , and wire goes to the driver's door window , just wondered anybody had pictures of knowledge
