speaker issues
Started by Zxrob, October 27, 2019, 19:49
Zxrob
Hi all
Passenger side speaker is not working, slight noise from the tweater at the top, I suppose the easiest way to check is door cards off and swap them over, if that does not work, what next
Cheers Rob
Adventure before dementia 😁
s12vea
Easy enough to take the door card off and check.
Is the Head unit standard? If not check the iso connector on back of unit.
TF204 Blue
Another one won't hurt  .....
Zxrob
Quote from: s12vea on October 27, 2019, 19:58Easy enough to take the door card off and check.
My head unit is a standard mr2 one , I have just replaced it with a functioning one, as the original in the car was hit and miss if it worked, the speaker is the same on both units
Cheers Rob
s12vea
Hopefully it's just the speaker has failed. Or if they are after market speakers fitted could be loose connections or broken wire
TF204 Blue
Zxrob
I'll investigate next weekend, time and weather permitting
Rob
I have a couple of spares kicking around...
Bossworld
This happened on my mum's car (driver's side)
Transpires the door speaker was knackered, though no visible issue/tear etc.
Had Dick Sloan send out one from a breaker as I didn't have time to start making MDF rings etc. for aftermarket ones (though I know that would be a far better option).
If you have time you can whip the door cards off as you've suggested as the connector will work on the 'other' side speaker. Though I think the speaker connection position is handed so you will need one for the proper side.
Bit of a ghetto fix but on my stepdad's suggestion we wrapped the rear of the replacement in a plastic bag, in case it had been caused by water ingress.
Zxrob
Well it turned out it was the speaker gone
All fixed now :)
Rob
BahnStormer
Quote from: Bossworld on October 28, 2019, 16:22This happened on my mum's car (driver's side)
In case anybody is hitting this issue and fancies a speaker upgrade - just search for "Speaker Adaptor for Toyota Corolla E12 MR2 Avensis 165mm 6.5 Speaker" should get you some options for speaker plastics for ~£5 inc delivery on Amazon/eBay and then you can just fit a decent set of 6.5" speakers....
Bossworld
Quote from: BahnStormer on November 11, 2019, 13:01
Good knowledge, wish I'd known that at the time!
BahnStormer
Quote from: Bossworld on November 11, 2019, 15:27Good knowledge, wish I'd known that at the time!
Ta. Sorry, I realise the advice is a little late and not trying to rub it in... just trying to give the next people in the same position an easy out.
By the time you've bought a nice set of components and the required Dynamat, it will cost a lot more... but at least you get an audio upgrade for the hassle and I couldn't bring myself to fork out ANY money for the ropey cardboard Nokias that were in my car as stock....
Not That Matt
Quote from: BahnStormer on November 11, 2019, 13:01In case anybody is hitting this issue and fancies a speaker upgrade - just search for "Speaker Adaptor for Toyota Corolla E12 MR2 Avensis 165mm 6.5 Speaker" should get you some options for speaker plastics for ~£5 inc delivery on Amazon/eBay and then you can just fit a decent set of 6.5" speakers....
Yes, they are much better than making your own. I used them when replacing the horrors of past bodges and they worked a treat. One of the previous owners used MDF and it was disintegrating, though better than on the passenger side where the (broken, mismatched) speaker was just flopping about. I'm quite happy with the JBL Stage 600CE units, the tweeter fits perfectly in the original tweeter hole with the rear cup glues on to the back to retain it. They would benefit from an amp.
BahnStormer
Very neat - not sure if the back section of padding is overkill though.
I use Dynamat Xtreme (I think the pack is for 2 x 10"x10") and I only cover the front section of the door, approx 2 inches either side of a 6.5" speaker and then I put the circular cut out on the inside of the door directly behind the hole - no idea if the last bit makes a difference though - just seems a waste not to.... definitely no vibrations or feel any sense that I need to pad out the back of the door.... that said - it's probably double the weight and cost of the regular Dynamat / other padding.
Not That Matt
More than likely, but the plastic sheet had been well damaged by the last person in there so it's solving two problems. I did inside the door as well for extra overkill. The meterial was left over from my brother's Defender which is partly why there's a lot of funny shapes. The doors do have a nice thunk now!
BahnStormer
Quote from: Not That Matt on November 18, 2019, 20:05The doors do have a nice thunk now!
That's why I put hte extra circle on the outside layer - just a little more damping to stop any rattles from the speakers, etc...
Bossworld
Seeing as winter maintenance hasn't been as taxing as previous years, I revisited this thread and I've ordered these: https://www.ebay.co.uk/itm/2pcs-Stereo-Speaker-Wire-Harness-2pcs-Horn-Speaker-Adapter-for-Toyota/173939418692?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
Hopefully the right ones!
The hunt is now on for some speakers, the JBL 600CE seem the sensible option if the tweeters fit, I'm a little unsure as to what will need to be crimped/soldered wiring wise.
On the other hand I wondered if these were worth a punt for £20 less?
https://www.amazon.co.uk/dp/B001MWX0SY/?coliid=I2KQGIQJMBRYDZ&colid=ZKU2NPZRC6YI&psc=1&ref_=lv_ov_lig_dp_it
Bossworld
Got some cheapo speakers from Halfords, starting to wonder if I made a rod for my own back ditching the original tweeters.  Just trying to figure out how to secure mine now.  I smashed the old tweeter casing off the original bracket but found the circle part is pretty much part of the structure.  Was probably going to go without those brackets unless they do something to support the doorcard itself (seems unlikely).
I think I 3m taped and cable tied mine in place, I had other issues with the chrome ringed tweeter covers on the door cards not fitting over mine. Out with the Dremmel...
Bossworld
Quote from: Call the midlife! on January 29, 2020, 16:03I think I 3m taped and cable tied mine in place, I had other issues with the chrome ringed tweeter covers on the door cards not fitting over mine. Out with the Dremmel...
I've got some metal retaining rings with the new ones and some backing covers. Pushing everything together into the doorcard it's about 80% snug but thinking of maybe using a dab of silicone on the rear side of the doorcard? Mine will have to be mounted through the card I haven't got the patience to try and line up to the original mount and it'd leave a hole
Bossworld
I decided to (didn't have any adhesive in the house!) silicone mine in place, hopefully means no vibration and they'll cope with doors being opened and shut. They're only on the slightest of angles towards people now but hey ho
Just wondering what you did with your crossovers? I've stuck mine to the reverse of my flashing but that means they're the wrong side of the plastic sheeting (if that even does much anyway).
Struggling to think of where they can go in front of the sheet, other than possibly up near the upper handle securing screw. But there's none of the black tarry stuff on that part of the plastic anyway
Thinking maybe just clingfilming it or using a plastic bag and zip ties? Is there even any point? The new woofers won't have the plastic shrouding of the originals, but that soggy MDF a few posts up is giving me food for thought
Quote from: Bossworld on January 30, 2020, 17:32
I'm sure I just stuck my tweeters to the existing door mounts with the double sided pad to stop vibration and secured them with the ties. I got some small connectors with bare tails and linked them to the existing crossovers etc. So everything is pretty much covered by the original plastic, I think, having said that the original plastic bit the dust last year.
mr9
Are the cheap ones a noticeable improvement on stock?
I'm thinking of adding to the pit of money I'm spending on the car and wondering how much you need to spend for "decent" speakers.
I had a sub but couldn't get on with fitting it under the dash and not sure I want it right by my legs if I was to crash.
Bossworld
Quote from: mr9 on April  1, 2020, 13:29Are the cheap ones a noticeable improvement on stock?
From the limited time I've had back in the car this month, those cheapo Halfords ones were fine. I do have an all in one sub in the rear bin though.
Difficult to define improvement but they are clearer than stock, perhaps at the expense of low end (I did a 50/50 test in that other thread I started).
