Aerial woes - solved!
Started by swampy_donkey, September 28, 2013, 20:10
swampy_donkey
Hi guys,
This problem will just not go away.  My aerial  will not go up an down. I have fitted an amplified windscreen aerial internally behind the glove box, gives half decent results for fm reception but still patchy.
I am loathed to fix the powered aerial because it looks like a  toy car with it raised. I will, however this as a last resort.
Before I do, what alternatives are there? I bought a bee sting aerial, but I'm advise it will be a pain in the bum to fit.
What solutions are there? What have you guys done?
Any ideas/suggestions/solutionsuch appreciated.
Rob
K&N panel filter - Markiii Pipe - TRD Style Bar - Chrome Filler Cap - Hard Top - Clear Side Indicators - Visor Plugs - Dev\'s Keyhole Covers - Silver Callipers - Pioneer DEH-4400BT + CD-SR110 - Red Leather Interior - Red footwell LEDs - Mud Flaps - Custom fit luggage - OBDII reader
Davred
I've stuck with the oem aerial by removing the toothed drive, then unplugged the lead into the relay behind the drivers bin to disconnect the motor.
This allows me to pull up the aerial manually, but not all the way, so it don't look daft!
Result is a good signal and a reasonable look with a shorter aerial.  s:D :D s:D
W. Red. Black leather. Facelift wheels.Toyo T1R. Pre-cats removed. Matts TTE style chassis brace. 2003 facelift front brace, FK lowering springs, Dev keyhole covers, tte rear grille. Tanabe G-Power Medalion exhaust, JSpec nose badge, mongo's, front strut brace. Matt perf engine rebuild May 2014.
trevsmr2
Toyota sell a fixed mast aerial to replace the electric one ,or fit a S2000 aerial instead
 m http://www.ebay.co.uk/itm/HONDA-S2000-A ... 3f299ef104 m
tomaky
Well i use mine manually and i actually prefer it i dont need to put it fully up to get signal a foot of aerial is usually enough for me.
Westfield Seiw
Ex - 2005 Porsche Cayman S
Ex - 2003 Sable
Ex 2004 Blue  Roadster RIP
swampy_donkey
Thanks for the help guys, any more details on the Toyota fixed mask? The s2000 one looks food though.
My present solution is using the bbc iplayer app through the stereo.
trevsmr2
Quote from: "swampy_donkey"Thanks for the help guys, any more details on the Toyota fixed mask? The s2000 one looks food though.
let us know if you manage to get one
 m http://partsfactory.camelbacktoyota.com ... 6309-17100 m
part numbers for both
86300   ANTENNA ASSY, W/HOLDER
86309-17090   MOTOR ANTENNA
86309-17100
frogger
I think you were on the right track with the powered internal aerial, just put it in the wrong place!
I have positioned one behind the rear view mirror (so stuck on the windscreen), and the reception is fantastic, even in areas which were patchy with the normal comical aerial!
swampy_donkey
Do you happen to have any pictures of that Frogger?
swampy_donkey
Quote from: "trevsmr2"
86309-17100
Do these part numbers look right?
86309‑17100
86309‑35100
86392‑17110
Thanks Trev! Am i guessing correctly the part(s) I need is/are 1, 2 and 3 on the diagram? I'm after the not motorised aerial. Cheers
trevsmr2
Yes the top picture is the motorised one ,bottom is manual
as in the link i posted
frogger
Quote from: "swampy_donkey"Do you happen to have any pictures of that Frogger?
Normal view (what you see when driving):
Was tempted to blank off the LED, but didn't find it to be an issue in the end.
View from underneath angle (bars not visible from normal driving position):
swampy_donkey
Quote from: "frogger"
Does this give you a decent signal/reception then?
Has anyone tried this http://www.amazon.co.uk/TOYOTA-RUBBER-VANDAL-MOUNT-AERIAL/dp/B008D0JAJQ/ref=wl_it_dp_o_pC_nS_nC?ie=UTF8&colid=3FNXYRMBZTKLT&coliid=I1Q1L7ULC5IC20? What do you guys think? Looks like it could be angled to suit the MR2.
trevsmr2
The problem with any aerial like those ,is that the hole in the wing is too large ,so you would need to use large washers, and you cannot get a good earth for the signal ,also due to the shape of the wing, a flat washer underneath just dents the wing when you tighten it
best bet is to remove the mast from the damaged aerial and replace it with the mast from a roof type aerial
or get the manual aerial that Toyota sells ,or fit a Honda S2000 aerial
 l viewtopic.php?f=31&t=41659&p=490780&hilit=alternative+aerial#p490780 l
frogger
Quote from: "swampy_donkey"Does this give you a decent signal/reception then?
As per above - reception is fantastic, even in areas which were patchy with the normal comical aerial!  It is at least equivalent in reception to the standard aerial, and in some areas better.
penn
Any info on what part this is and how to fit it? What have you done with your old aerial hole?
swampy_donkey
 m http://www.amazon.co.uk/Carpoint-201000 ... een+aerial m
I think they also have them at Halfords.
It requires one lead to an earth and one to a live source. The remaining lead is plugged into the stereo.
I left the original aerial in situ.
Hope this helps, Rob
swampy_donkey
86309-17100
I managed to of this today! It took about 2 or 3 hours at a leisurely pace, no real problems apart from removing the old 'ornament' (the rubber bit on the outside). I'll post some pictures soon. If anyone else needs any advice then give me a shout.
Rob
swampy_donkey
What do you guys think? This is a solid aluminium aerial, I'm ideally after a similar length flexible rubber one, any suggestions?
trevsmr2
what are the fittings ?
 m http://www.ebay.co.uk/itm/VW-AUDI-SEAT- ... 4179bf258a m
not sure if these are rubber ? look it
 m http://www.ebay.co.uk/itm/GENUINE-CITRO ... 5444362%26 m
 m http://www.ebay.co.uk/itm/Short-Stubby- ... 4abf4e3d27 m
swampy_donkey
They look like exactly the kinda thing I'm looking for. It's supposed to be 5mm I think. Thanks Trev.
On second thoughts, I could just go to a scrappers at the weekend! Doh' should have thought of that yesterday.
swampy_donkey
If anyone is interested the two part numbers you need are
86309-17100 and 86392-17110
They are for the internal replacement and the rubber 'ornament'.
Quote from: "swampy_donkey"If anyone is interested the two part numbers you need are
id like to do this on my car - did you go to CTP?
bluesmoke
Well pleased to find this! I'll have to get this myself once the other jobs are done.
Think I'll buy a base and find an aerial mast form eBay - factory one from CTP is £35! Toyota price lottery strikes again!
trevsmr2
