Dashboard pin out, and greddy loom connectors?
Started by stupink, April 20, 2014, 15:25
stupink
After the pinout for the dashboard/loom
I'm after RPM signal, and illumination feed.
Also after a source for the inserts that go into the Emanage looms, I have a blank pin i want to use, so need the insert thingybob you solder the wire to, the ones i have don't seem to fit, a different style.
