lightweight battery
Started by keljon, May 9, 2016, 16:48
steveash
It was an aluminium racing mount. It looks very similar to the GPR4 ones on Demon Tweeks etc but they are larger so I got mine from the well known auction site for £40. Fits nicely although the phrase "remove all burrs and sharp edges" can't be often repeated in their production facility! I put a layer of 10mm foam on the original tray, inside the mount and under the original top bracket and it foitted like a glove. Vardey do recomend the foam to stop the battery being damaged by vibrations.
steveash
If you are searching on 'the bay' then look under "Alloy Battery Tray Suits RMD25 Red Top 20 25".
