Where is power steering relay/which one is it (mk3)?
Started by SCHNICK18, September 7, 2016, 21:35
SCHNICK18
Hi guys,
So I have an issue with my power steering and using the pin diagnostic cheat i've found that code 52 is present which relates to the relay or wiring to the EHPS.
Can anyone tell me where it is located (under bonnet perhaps?) and if so which one is it? Does not appear to be a diagram on the fusebon lid under bonnet.
I want to check it with a voltmeter and replace if needs be.
If I do need a placement is it a general relay or is there a specific spec I need?
Thanks guys!
cabbydave
Its in the front fuse box one of the blue ones if my memory serves me right
