Dashboard Illumination Lights not working
Started by Poidster, September 30, 2016, 20:05
Poidster
Hi,
Has anyone got any suggestions as to what might cause the lights to fail, all the dials actually work as well as all the warning lights etc, its just the illumination. I have checked the 7.5 Amp PANEL fuse, changed it, twice, but its not that. I should say I had been messing around with some blue LEDS in the cluster, work ok for the SMT indicator and odometer, wondering if Ive fried anything other than the fuse (which is OK) been driving round at night with effectively no dash display which I probably shouldn't.
TIA
Have you checked the connections in the beach of the cluster?
Have you also checked the illumination control dial?
The only thing that springs to mind is that leds need the right polarity, could they be in the wrong way round?
Not all the lights though Simon.
Jock
Agree with StuC and the illumination control dial. Replace one led with a working bulb   s:wink: :wink: s:wink:  .
There is some info about leds here;
 m http://www.mr2spyder.net/spyderweb/inde ... entry10603 m
Not sure if it will help but may stop you wanting leds!
Fin
I did the same to mine about 18 months ago. Ended up using an overlay. Be interested in any fix for this.
The roof is down on my MR2,
Poidster
Ive replaced all the LEDS back to incandescent and still no joy. The SMT Indicator LED light ive left in and The odometer  they work fine now. The SMT light responds to the dimmer switch. I think ive loosened a cable in the connectors. Time for an auto electrics bloke now
Could be a loose connection either in the connectors or onto the pcb.
The auto electrician should find this quite quickly.
