under dash sub
Started by Anonymous, November 15, 2005, 20:55
fitting some speakers behind the seats. the 2 side compartments that you can remove for extra space in the cubby holes seems the best, i was thinking of putting them back in the car, cutting holes in them and fitting them in those. has anyone else done this?
edit, renamed this thread seens its gone into sub talk
Yep, plenty of people including myself - it works well too. See my thread here -  m http://www.mr2roc.org/phpBB2/viewtopic.php?t=1200 m
no i mean inside the cubby holes, to the sides (cut into the parts you can remove for extra space)
Ah, sorry. I don't think anyone has attempted that - also those bits are rather flimsy, I reckon add some weight to them and they would constantly fall out unless you added some additional mounting points. Also, with the cubby doors shut would you really hear them?
with the doors shut it'll sound muffled to hell, unless your dumping the doors that'll never work, sorry to be blunt
yeah i know it'll be muffled, but surely i can use those back speakers as a sub then? it'll sound more bass-y with it being muffled
Quote from: "razorsharp192"yeah i know it'll be muffled, but surely i can use those back speakers as a sub then? it'll sound more bass-y with it being muffled
no you cant, muffleing a component wont give you the bass frequencies of a sub, it'll sound dead and dull. There is no replacement for a sub, they have a lot larger stroke in there movement and a larger surface area to move the air required for those low frequencies
I suppose you could replace the side panels with some flat bits of MDF or ply, that use the standard attachments (you'd need them removable if you have a hardtop, as you have to get to the rear window heater wire there), then cut most of the main doors away and cover them in acoustically transparent material - then you'd maintain the storage area and get good sound, too.
Assuming you can find a way of attaching bits of wood where the side inner panels used to be.
or you could build one of these
its going back in this arvo following the softop install
edward.carter
Mmmmmmm   s8) 8) s8)
yeah i actually want to be able to use the storage bins though
i'll give my idea a go i think, if it sounds crap i'll just take them out, cause i've not got the side panels in at the mo anyway so it doesnt matter if i wreck them
Quote from: "razorsharp192"yeah i actually want to be able to use the storage bins though
i can as well, i've got a spare set of doors for the bins and i can swap them over in 10mins, i've got a trip on the amps so 1 press and i can pull the speakers out and put in the blank doors. problem sorted
sounds like far too much effort to me. i'll give my idea a go with some little subs in either side, see how it sounds
Will the std Fischer Price cope with adding rear speakers then? what is the recommended wattage that can be used without amplifying?
I hav ebought the Focals for the front, but would like a nice set of speakers to fit into the bins, any reccomendations & prices?
Thanks,
Chris.
LeeUK
Waste of time mate, if you want a sub sound you have to give up some of you storage space for a sealed box for the subs else they won't work properly.  The only other solution is an under dash sub sub box.  I personally, if I was going to fit another sub would go for a fiber glass box like buster had in the rear bin with either an 8-inch rainbow or focal sub (focal is louder apparently).  I wouldn't waste my money on trying to fit subs in those corner bits of plastic as they won't fit, they're not sealed and even if they were sealled they would never have enough air volume within the box to work well (it's all about the volume of the box  s:wink: :wink: s:wink:  ).
I hope this helps, going on the fact you do not wish to sacrifice space I would fit an under dash sub (I may make one at some stage when I have some free time!)
I've had some 6x9's sitting in a box for a while, they're the new Alpine type R's.  They're pretty good speakers, look rather cool too!  I've fitted them in the rear doors.
[size=100]JELBE[/size]
[/color]
Quote from: "LeeUK"Waste of time mate, if you want a sub sound you have to give up some of you storage space for a sealed box for the subs else they won't work properly.  The only other solution is an under dash sub sub box.
I didn't want to loose storage space so fitted decent door speakers (Boston Acoustics) , under dash sub, on amp under the rear plastic feeding the sub, and one on top of the plastic for the door speakers. This takes the space taken by the jack which is now in the front with the wheel and it sounds sweet  s:wink: :wink: s:wink:
I have an unused UD Jr enclosure, too  s;) ;) s;)  (Under dash enclosure to take a JL 6W0 sub)
Quote from: "aaronjb"I have an unused UD Jr enclosure, too  s;) ;) s;)  (Under dash enclosure to take a JL 6W0 sub)
Snap this up as they are a great bit of kit  s:wink: :wink: s:wink:
have a read
 m http://www.diysubwoofers.org/faq.htm m
just a few basics of building a descent sub unit and what happens if its in too small a space
Liz
How much for the sub Aaron sweeedie?
is there a "make your own under dash sub" tutorial somewhere? so its the right size/shape etc?
ps i'm 2nd in line for the sub if its for sale!  s:D :D s:D
Quote from: "Liz"How much for the sub Aaron sweeedie?
Bearing in mind it was £180 new I think, and it's not been out of the box. Oh - remember it's driver-less (I never got around to buying the sub to go in it, so it's just the enclosure), when it was up for sale earlier this year I said £150.. There were no takers, though, and since it's you - make me an offer  s:) :) s:)
Quote from: "razorsharp192"is there a "make your own under dash sub" tutorial somewhere? so its the right size/shape etc?
I don't think so - not that I've seen anyway.. the company making them kept their design a pretty closely guarded secret (and they were expensive, as you can see). There was talk of someone else starting to make them, but I don't think that ever got off the ground.
cant one just be made from mdf? if you've got one can you please take some measurements?
  s:D :D s:D
Liz
Quote from: "razorsharp192"cant one just be made from mdf? if you've got one cant you take some measurements?
Please?
Aaron I will pm you my dear!
If you do a search for under dash sub you'll come across a post which contains both pictures and dimensions.<VBG>  I would provide you with the link but I don't know how.
