Fitted Head Unit - No power- Help!
Started by Anonymous, August 24, 2007, 18:59
Fitted a new head unit and fascia. Test fit no problem, checked that is was functioning and the tft screen had enough room to 'roll' out - all ok.
Then placed it all back in and screwed it all in to place - NO POWER!
Checked the unit's fuse - all ok. Checked wiring, double checked connectors all ok. Thinking - must have blown the unit - damn. Placed original MR2 unit back in - no power to that either.
Checked all fuses in front bay and engine bay - all intact (not sure which is the radio one and where it is though,  so checked all). Checked all wiring again - looks all intact. Am I missing something? Is there a fuse box somewhere that I have missed or some wiring adapter?
Thanks in advance for any help with this matter.
Andy.
Did you check the fuse box that's in the end of the dashboard?
Open the passenger door and open the little flap that's in the flat end that's visible with the door open..
Thanks. Sorted now. I knew there had to be another fuse box somewhere....
Looked under dash, passenger and driver, behind seat, in storage compartments, etc
Didn't check the dash end. Anyway, thanks.  s:D :D s:D
