There was a horrible metallic clanging noise om way to work ! One of the TTE tips was dragging on the road.
Managed to use a Cat 6 cable to tie it up so could get it home.
Took it to the garage today and clamped it back on but I need a ring gasket where it joins the back box.
I called at the Toyota garage and they only have a part for the standard exhaust.
Can anyone help with the part I need ?
Many thanks
I believe this is the part after searching here. https://www.ebay.co.uk/itm/CEG112-Exhaust-Ring-Gasket-For-AUDI-80-90-FIAT-TEMPRA-TIPO-VOLVO-240-VW-GOLF-/250905464352
Did it work?
I swear I saw an old post recommend a gasket meant for a different make of car, could well be what you've found.
I bought 2 new ones for my TTE and had no problem with them.
