News:
MR2ROC Club Gathering!
Sunday 13th July CANCELLED
Main Menu
Pre Post Facelift Engine Numbers
Started by wbarrwebster, May 27, 2011, 18:00
wbarrwebster
Hi,
Just read the  2"new" engines in 6 months horror story  from a recently new member.
Surely this begs the question that I'm sure I brought up a few years ago...how can we indentify pre and post facelift engines?
Engine Numbers? British Leyland changed the timing on the Metro so many times you had to check the Engine number to confirm the exact timing for the car...
Surely there must be some way, ideally as easy as possible, to tell if the engine is 1999-02, 03to whenever or year of manufacture, that is, apart from the Reg.
I realise it's not the total answer God forbid you have to buy a second hand engine....but it's someway along the line, any information is better than none!
I can't believe Mr T would stuggle to indentify an overbore threatened engine.
While we don't have this information, any second hand engine dealer/ scrapper has members by the shorts. "Just pulled it out an 06 plate pal, lovery car, like new it was, only done 2 thousand miles, owned by a Vicar's wife!" Aye and the rest!!
With the amount of technical brains in this outfit , surely someone can  up with a definitive answer...?
I''ll shut up now!!
B AKA Victor Meldrew!!
W. B. Webster
Maybe we could tie engine numbers to production numbers to get a better idea,i.e if we knew the engine number of a late 02/52 and an early 03/53 and 06/56 or TF300 hopefully we could work out the range of engine numbers if this makes sense?
 l viewtopic.php?f=9&t=30781&hilit=production+numbers l
mrzwei
There was definately a post on Spyderchat about this a few years ago, I remember because my 2001 was on the cusp so it could have gone either way. As it happened, the numbers said old pistons and rings etc.
You could try a search on there or brave a new post.
Ex.MR2 SMT sadly missed.
i have a 52 plate facelift  thats engine number could be of help if someone took the time to collect others and look into it
Quote from: "burty"i have a 52 plate facelift  thats engine number could be of help if someone took the time to collect others and look into it
Without giving the exact number could you list it to the nearest 100?
My MR2 was first registered 14/07/2000 with a chassis/engine no to the nearest 100: JTDFR3207000162**,engine number 1ZZ 05385**.
wbarrwebster
HI,
Good stuff so far....to be frank, I would have thought it in everyone's interest to have some form of reference.
Maybe the Mods..if they felt it would assist, could set up a folder where motivated members could confirm age, reg date and engine number, This would eventually, with enough response, give us a feel for the issue.yes/no?
B
W. B. Webster
ring toyota gb
if you phrase it correctly, i.e don;t accuse them of killing oue cars with dodgy engines/precats
they may be more helpful than you think
Quote from: "wbarrwebster"HI,
B
I would say see how this thread goes as this info could be useless if there is no sequential pattern to the numbers or there is no real response with members not giving the info.Why not post your details too and help get the ball rolling.
will look at my old engine later and post up.
All the info is on your log book.  s:D :D s:D
Il look up mine no probs not at home till sunday though, mine has to be one of the first new piston ring design  not many 52 facelifts around to my knowlage its a feb 03
wbarrwebster
Quote from: "markiii"ring toyota gb
if you phrase it correctly, i.e don;t accuse them of killing our cars with dodgy engines/precats
Yeh, the thought crossed my mind as I'm sure the Haynes on the old Metro ran engine numbers and I assume that came from BL.
Anyway.
Reg Date:                           Variant:                             Engine No.
 28.3.2001                  JTDFR32020000338 10         States "No known"?
As stated previously  V5C Form.....has the info.....I'll try and make the time next week to ingratiate myself with Mr T GB, meantime if anyone would like to add details would be helpful....IMHO we should have had some form of reference years ago!
B
W. B. Webster
Mike_V
2000 Roadster, chassis no JTDFR320100022037
Engine No 1ZZ0590932
If you wish I'm prepared to keep a register and see if there is any pattern to the engine numbers,
Mike
2004 Red edition in Sable.
wbarrwebster
Quote from: "Mike_V"2000 Roadster, chassis no JTDFR320100022037
Mike
Mike,
Me thinks that would be most helpful, hopefully there are enough replies for a pattern to develop and we can construct a reference. Meantime, I'll have a crack at Mr T next week.
B
W. B. Webster
Mike_V
For this to be of any use, I need as much information as possible and I hope that all members can get involved, it may or may not show a pattern but if it does then i feel that this is something that we all want to know.
feb 03
engine no 1zz12613**
as promised ,  s:D :D s:D
Well I thought there would be more participation in this considering a good proportion of us may need replacement engines in the future,disappointed!   s:? :? s:?
smarty72
Sept 03.
Engine no: 1ZZ14700**
current: Astral Black FL
Ex: Forest Green 2003.
dan_daran
1ZZ20948** (from celica donor)
How are you going to tie the engine numbers up with engine production dates? Registration date of the car is useless to you as is 'year' of manufacture, you need the month & year of actual manufacture in the factory.
Anyway, this might help. For all these parts I checked all production years, the dates listed are just the 'important' dates with reference to the particular year I copied & pasted from.
13011 RING SET, PISTON
13011‑22090 1ZZFE..ZZW30, STD (12/1999 - 10/2001) 1 € 142.92
13011‑22150 1ZZFE..ZZW30, STD (11/2001 - 07/2002) 1 € 142.92
The later part - 13011-22150 is then listed for all years through to termination of production. So the piston rings changed from 11/2001.
13101 PISTON SUB-ASSY, W/PIN
13101‑22030 1ZZFE..ZZW30, STD (12/1999 - 11/2001) 4 € 74.82
13101‑22031 1ZZFE..ZZW30, STD (12/2001 - 07/2002) 4 € 74.82
13101‑22031 1ZZFE..ZZW30, STD (08/2002 - 04/2005) 4 € 74.82
13101‑22032 1ZZFE..ZZW30, STD (05/2005 - 08/2005) 4 € 77.71
The piston changed twice - 13101-22030 is listed for all cars to 11/2001. 13101-22031 is used from 12/2001 through to 04/2005 and finally 13101-22032 was used through the end of production.
13201 ROD SUB-ASSY, CONNECTING
13201‑29038 1ZZFE..ZZW30 (08/2002 - 06/2004) 4 € 121.18
13201‑29176 1ZZFE..ZZW30 (07/2004 - 12/2004) 4 € 123.38
Earlier part runs from beginning of production to 06/2004. Later part runs till 2005 when:
13201‑09201 1ZZFE..ZZW30, (L) 4 € 149.79
13201‑29038 1ZZFE..ZZW30 4 € 121.18
13201‑29176 1ZZFE..ZZW30, (J) 4 € 123.38
Apparently engines were produced with three possible parts in use..
Also:
17141 MANIFOLD, EXHAUST
17104‑22060 1ZZFE..ZZW30 1 € 1,224.88
17104‑22061 1ZZFE..ZZW30, *115=TOYOTA/00-/Y 1 € 1,224.88
Prior to 2002 only 17104-22060 is listed, in 2002 both are listed and post 2002 only the latter (newer) part is listed.
So .. out of that myriad of changes, which one do you want to gamble was the one that fixed the issue? Is it the rings & pistons which changed in December 2001, or was it the manifold that changed some time in 2002 with no referenced production date?
cclarke99
aaronjb, I assume you used the ToyoDIY site for this info. I don't know how reliable the information is, but I would recommend it as a good starting point if anyone is  looking for info on part numbers, dates, etc.
On a slightly different topic, for those who are looking for interchangability this site now has a "where used" function, so for example the short engine in my car is part number 11400-22060 which is used in
08/1999-06/2005 TOYOTA CELICA ZZT23
05/2000-10/2005 TOYOTA RAV4
No menion of the Avensis, which (for a 2002 model) is part number 11400-0D060, unique to the Avensis
This throws up all kinds of interesting (for some people) data, e.g. one camshaft also fits the Corolla,  Avensis, Celica,& RAV4, whilst the other applies to the last two only. The ABS speed sensor is surprisingly unique to the MR2, whilst the EFi relay (same as the cooling fan) is used all over the place, as you'd expect.
Quote from: "aaronjb"How are you going to tie the engine numbers up with engine production dates? Registration date of the car is useless to you as is 'year' of manufacture, you need the month & year of actual manufacture in the factory.
The magic number is 2003,the idea of this is to check if the used engine from an unknown source is from a 2003 onwards as claimed by the seller some of which have cottoned on that everyone wants a 2003 onwards.Surely if we can achieve this then it can only be a good thing and stop people being ripped off buying high mileage prefacelift engines advertised as good low mileage facelift ones,the few participants engine numbers so far seem to indicate a low to high sequence so if we could get some more participants to look at their log book and take part we may be able to nail this.
info received so far:
registered 14/07/2000  1ZZ 05385**
2000 Roadster               1ZZ05909**
registered 04-09-2002   1ZZ10387**
feb 2003            engine no1ZZ12613**
Sept 2003        Engine no: 1ZZ14700**
2005                             1ZZ20948** (from celica donor)
First registered 04-09-2002
Variant ZZW30(K)
Version ZZW30R-AKMQHW(1D)
Engine number.1ZZ1038738
94,000 at demise.....never used oil or water from one service to the next.
iPap
There is info from Toyota stating the date that the change happened was 21July 2005, when the piston and rings were changed. Production stopped in October 2005. This change was to reduce the risk of higher oil consumption. I have been given this info by two people with connections to Toyota.
The change occured from chassis number jtdfr320100074980 until the end of production, last car built being jtdfr320100076411.
Hope this helps!
2001, Black MR2, Elise Leather Seats, Aircon and Factory TTE Kit, BC Coilovers, SP Brace, Corkys Front Brace, Devs\' Front Bushes, Rebuilt Toyota 1ZZ Engine, Head and Six Speed Box, Cobra Twin Exhaust, Decat Manifold, Short Shift and Solid Bushes, etc...
