The Academy => How To's => Topic started by: Anonymous on December 7, 2012, 11:25
Title: SMT APS sensor repair
Post by: Anonymous on December 7, 2012, 11:25
My Toyota MR-S no longer responding to the gas pedal, the cause of failure was in the APS sensor  new APS in Russia worth $ 580  s:scared: :scared: s:scared:    to order 18 days from Japan! Because it is expensive and a long wait, I decided to fix a broken sensor.
1.remove the throttle assembly and unscrew 4 screws APS sensor and remove it
(http://i1288.photobucket.com/albums/b482/MRT1GO/IMG_0511.jpg)
2.gently warmed latch hairdryer and turn down the sides
(http://i1288.photobucket.com/albums/b482/MRT1GO/IMG_0512_zps9e0c83fd.jpg)
3.grind down the rivet and remove the plunger
(http://i1288.photobucket.com/albums/b482/MRT1GO/IMG_0514.jpg)
4.remove the lid and sealing ring
(http://i1288.photobucket.com/albums/b482/MRT1GO/IMG_0516.jpg)
5.within the board is 4-pin, heat the soldering iron and remove the switching circuit
(http://i1288.photobucket.com/albums/b482/MRT1GO/IMG_0520.jpg)
6.inside there are contacts that are not pressed to the board and hang out, because of this there is no contact and the gas pedal does not work
(http://i1288.photobucket.com/albums/b482/MRT1GO/IMG_0517.jpg)
7.small screwdriver gently bending up contacts
(http://i1288.photobucket.com/albums/b482/MRT1GO/IMG_0522.jpg)
8.glue drips on the plate with contacts
(http://i1288.photobucket.com/albums/b482/MRT1GO/IMG_0523.jpg)
9.switching circuit wipe with alcohol or solvent and put back
(http://i1288.photobucket.com/albums/b482/MRT1GO/IMG_0519.jpg)
10.soldering iron to solder 4 pins
(http://i1288.photobucket.com/albums/b482/MRT1GO/IMG_0525.jpg)
11.put the O-ring and cover
(http://i1288.photobucket.com/albums/b482/MRT1GO/IMG_0526.jpg)
12.heat the holders and bend, put plunger and gently bump the awl
(http://i1288.photobucket.com/albums/b482/MRT1GO/IMG_0529.jpg)
bolted to the throttle and drive on!))))  s:P :P s:P
traveled 2000 km (1243 mi) all works well  s:) :) s:)
Title: Re: APS sensor repair
Post by: iPap on December 7, 2012, 11:28
Great write up and great self diagnostics!
I'm sure that will help someone at some point.
Post by: onion86 on December 7, 2012, 12:08
Nice work, thanks for the write up  s:) :) s:)
Post by: dcod on December 7, 2012, 12:58
Wow, what a first post   s:shock: :shock: s:shock:
Welcome ... you're VERY welcome here  s:D :D s:D
Title: APS sensor repair
Post by: simers on December 7, 2012, 13:17
Welcome along and great bit of work there fair play to you
Post by: Wabbitkilla on December 7, 2012, 14:59
Such a good write up deserves it's place here, thankyou for your clear and complete work
