As title, does anyone know the exact figure?, obviously i have a rough figure using rev counter/speedo. thank you..
I did have a spreadsheet with all gear ratios and specs.
Speed to rpm can vary depending on factors such as wheel diametre, tyre profile etc.
With a standard FL set up I think it worked out at 404.7 rpm per 10mph
Mind you this gives a theoretical top speed at 6500rpm of 162mph :)
I will see if I can find the file when I get home, unless anyone else can help
https://wahiduddin.net/calc/calc_speed_rpm.htm
Enjoy
the 5 speed is 146 @ 6500 revs
