Taken from my build thread..
I was 'allowed'some time on the car this afternoon.....
So set about having a trial fit of my Bofi Racing tyre rack.
This should enable those who track their twos to take spare wheels and tyres with them.
https://bofiracing.co.uk/skidnation-tyre-rack-mazda-mx5-na/ (https://bofiracing.co.uk/skidnation-tyre-rack-mazda-mx5-na/)
All in all bolted up pretty straight away.
One whole to elongate and another new hole between the two already there.
The bars that come with it are too short but nothing a bit of box section from work can't fix.
Looks a neat job!
Not seen those before, very neat.
Could be a useful way of adding luggage capacity, or maybe a BGW?
Is anyone into canoeing I wonder?.....
Quote from: Topdownman on September 27, 2020, 16:56Not seen those before, very neat.
When the Mrs came out and saw what I was doing she thought it was a BGW and said it would be grounds for divorce!
So maybe now isn't the time to tell her I've got one waiting to go on 😂
Nice, i saw a guy at one of the sprints in a MX 5 with this on pretty handy.
Is the metal strong enough to support a set of tyres?
The roadster hasn't got the strongest chassis.
What about insurance as its not made for an mr2?
Suppose it just counts as a mod.
Probably not the best "mod" when fully laden to assist spirited driving.
Quote from: 1979scotte on September 27, 2020, 22:00Is the metal strong enough to support a set of tyres?
Only one way to find out, but seems so.
Quote from: Joesson on September 27, 2020, 22:05Probably not the best "mod" when fully laden to assist spirited driving.
Not sure if trolling, but if you're driving spirited with this fully loaded you deserve everything you get.
It's literally for getting to the track unloading and swapping tyres over.
Quote from: Gaz2405 on September 28, 2020, 06:43Quote from: Joesson on September 27, 2020, 22:05Probably not the best "mod" when fully laden to assist spirited driving.
I think the old geezer was just having a laugh.
But at his age who knows.
Quote from: 1979scotte on September 28, 2020, 06:56Quote from: Gaz2405 on September 28, 2020, 06:43Quote from: Joesson on September 27, 2020, 22:05Probably not the best "mod" when fully laden to assist spirited driving.
It was a comment that was seeking a response.
Anyone in any doubt about the correct usage of the tyre carrier, after reading the response, should not be in any doubt.
I guess it goes without mentioning that the rack was intended for use on a car with a different front / rear weight bias and this loaded rack will affect the front/ rear bias of the 2 more so than on the intended vehicle. Rather than "spirited driving" a touch of caution will likely be employed.
As for the question of my age, I have sufficient years to be aware of the many things that can go wrong in life. Sometimes, at the risk of adverse reaction, I may recount a previous incident that ended badly.
Nice. Does the engine cover close properly? It looks like there's a bit of a gap next to the tail light in the last pic.
I've been thinking ahead for if/when I get coilovers as the idea of a 5hr round trip for my nearest track on solid suspension isn't filling me with joy. Some soft sidewall tyres for the journey would be nice, so this rack could be ideal.
Quote from: Roj on September 28, 2020, 17:23Nice. Does the engine cover close properly? It looks like there's a bit of a gap next to the tail light in the last pic.
It will close up with a little manipulation.
I have tried to do something similar in the past but noticed there was a curvature on the side of the wing (as can be seen in your second pic towards the right) that would require another bend to be made on the supports.
That made me give up as I dont have specialized workshop tools to make such a bend.
So I am surprised that you managed to fit those brackets that only have a 90 degree bend and still close the lid.
What is the thickness of the bracket ? maybe that is where I went wrong ....
Thread revival,
@Gaz2405 did you get this fully functional and road tested? Also presume you went with the mk2.mk2.5 kit?
https://bofiracing.co.uk/body-styling/exterior/boot-racks/skidnation-tyre-rack-mazda-mx5-na-nb/
Quote from: JB21 on August 2, 2022, 12:51Thread revival, @Gaz2405 did you get this fully functional and road tested? Also presume you went with the mk2.mk2.5 kit?
I went so far as buying the extra length tube I needed then did nothing with it!
