Anyone got the part nr for the bolts holding the rear brake pad bracket (torque plate).
Purchased at the local Toyota dealer part nr 90105-122208 but it is to long (5mm)
Quote from: MRSwede on October 16, 2023, 16:17Anyone got the part nr for the bolts holding the rear brake pad bracket (torque plate).
If I am correcting in my understanding of the part you want those you have are likely for the front. Unfortunately no part number.
I still have the old " bolts"/machine screws/ 12mm fully threaded that I removed from front and rear calipers.
The fronts are 30 mm and the rears are 25mm also have a captive flat washer.
PS This could be the part number :
59 (600, 44)
Yes The bolts i got from the dealer is probably for the front.
The rears are M12x1,25x 25, not that common in the local hardware store.
https://www.ebay.co.uk/itm/126074715735?hash=item1d5aa37e57:g:JjQAAOSwlBRk8Z-U&amdata=enc%3AAQAIAAAA4NdJeaPyk341v68IP1d4RsijiRui%2Bwp7AhNT2I45e2rij5Bmr6LFQb9NaF4rKz7P5MahHUdIDUZVwgWCIMYMh8St%2FKpYWfbyNUpszR%2F0JePvuadMXQjezbzoMhI29mIHVQunPjRF%2Bwp4WlHHygz9V9g%2F39m7Rdstm8zs6o6w6uDGkqtU4SdzMCkRxcN7R4jFxzmdJGqKzv2yEEDcOKepAXTWdQPWSeiNbKb8EUZYdg%2Fw29ECvarr%2BGojhlUBbXDi8FPq4Z27wVPRwEQa1xmo9p5e9ppaHNk4LF%2BApvVlfnj9%7Ctkp%3ABk9SR6z4ls3nYg
https://www.ebay.co.uk/itm/371143072619?hash=item5669d9db6b:g:6ZMAAOSwPhdVMMGq&amdata=enc%3AAQAIAAAA4CrZ2MH4qAPA2pBeyCjSAV3mTTxg67mO4tfseETxyKoXMDToZ8KysIsAoOjSDFDLELLamlYzsDEzJRT6UuDxctzKsz60A8MZOInbK1KcLBbXNdp8INT0JJVKFcRlcf6HjBa3BBxZseyDaCPC7%2BOUzxEoZ7XOOnQ4rGxJDQFqdte7UBExL%2FIY6ERqoNO73phBHi%2Fqsp2wlguaUjjPP8fat%2BpD8nxhjPGj8UgD9%2BgkYEim7zzuHFTsgGBJsRQ8Y3jN9flY4hKKhMELSxurMvf1mAw7AtIKKRRBTJD0A7lztJP3%7Ctkp%3ABk9SR6z4ls3nYg
