Volvota MR-T5 - A hello! and the story so far.
Started by Lord SanDisk, November 22, 2015, 20:54
Lord SanDisk
Hello everyone! This is my first post of many, and what better way to start it all off with the introduction of my "perfect car" which is still under development, ironing out all issues and the final phase of putting on a Luxuary Part kit.
For the purists out there, you might want to look the other way!
What I have basically done is taken a early 2002 high millage MR2 Roadster, dumped the old 1ZZ out and replaced it with an older B5234T Volvo 2.3 T5 turbocharged 5 cylinder engine! and thus the Volvota MR-T5 was born! (in the span of 9 months mind you!) as it currently sits it's pumping out the stock 225bhp 250 lb·ft which even in this stock power form, has transformed the car! I was not expecting such an increase in performance and feel! but here is the crazy part - We weighed the 1ZZ at 101kg ... The Volvo T5?? 132kg! (bare in mind everything that could be taken off has been) I wanted to build a car for one thing and that is to put a silly grin on my face! and boy, even in it's lowest, stock form, it already does!
My plans are for 500wbhp 400ft/lb and there are three things that need to change! the turbo, injectors and rods! At the moment it is being powered by the stock turbo with a set of 750cc injectors (stock are  315cc), with the injectors not even reaching 8% duty cycle! I have a GT35r turbo ready to pop on running low 5psi to 7psi of boost and eventually 18psi to 20psi once the rods have been changed. Why these specific figures? Well I want power ... and I reckon in a car that weighs so little, this is going to be plenty! Anyway enough of my babbling! PICTURES!!
Walbro 255 install
https://youtu.be/43wIpmbERTA
https://youtu.be/bZJaaawPRlQ
Everything has gone quite smoothly, and because the way the instrument cluster works (sending speedo from ABS sensors to cluster first) speedo is working perfectly, revs are too (the only exception is coolant temp! but that has been taken care of via the pillar pods show in the videos) I will keep this updated as I dive into the bigger turbo and eventually, once everything is complete engine wise :
Luxuarypart Gemballa body kit
Well, that's the most I have ever posted but wanted to share what's been done  s:) :) s:)  I might start doing a Vlog on the car soon! but yep, Hi - My names Luke, and this is my car.
tomaky
Welcome! And a volvo engine! Never seen before! Good luck with this very interested.
Westfield Seiw
Ex - 2005 Porsche Cayman S
Ex - 2003 Sable
Ex 2004 Blue  Roadster RIP
Like the look of this mate.
Very interesting.
Can I ask what gearbox you are running?
Lord SanDisk
Thank you! Yes I'm not sure if this has been attempted before!
Gearbox is a Volvo T5R manual 5 speed - I'm not sure how it will handle the power, but as it's pushing far less weight I can't see it being an issue but time will tell! The clutch will have to be up-rated.
andyroo104
Hi Luke and welcome,that looks like it will be one serious piece of kit,love it.
tomaky
Will be worth finding out the torque rating on the box for when you turn up the boost  s:) :) s:)
Westfield Seiw
Ex - 2003 Sable
My 230 bhp car is pretty fast I think yours is going to be frightening.
I don't mean that in a bad way either.
Lord SanDisk
Thank you for the welcome!
I will have to do some more research about the gearbox, I know only a couple that have over 400ft/lb - They both run the stock gearbox with the R clutch. At the moment I have both R gearbox and R clutch pushing over half the weight, so i'm being very optimistic!  s:) :) s:)
It did require a bit of alteration to the rear sub-frame though! As they are MASSIVE, big and strong ready for some power!
Just tried adding a car on the "garage" section but no 5 cylinder option!  s:( :( s:(  ha.
The only thing I need to change is the clutch master cylinder - The stock MR2 one does not throw far enough! but i'm tackling that after work.
Lord SanDisk
Quote from: "1979scotte"My 230 bhp car is pretty fast I think yours is going to be frightening.
I really can't wait to turn it up! to think ... 225bhp, 250ft/lb is going to be it's lowest power, it should be insane! It's going to be done in stages mind you - I have got a manual boost controller on it's way, will go from 7psi to 15psi, that should see 300bhp once I've dialed the 750cc injectors in properly, will be spending a few hours on the road and the laptop out! (with a friend) once that's done I will be taking it down to my local Dyno (Courten Miller) to see what's what.
The size of the turbo does frighten me!
While i'm here, brake upgrades! Car has new pads, discs and calipers - are there any bigger ones? or are the stock ones more than capable? the weight is pretty much the same.
cptspaulding
Very impressed.
Sounds superb on the youtube link too
tommyzoom99
wow a volvo engine never thought i would see that
very impressive must go rather well.
cheers tommy
My track project
viewtopic.php?t=51237
CrazySX
Welcome to the club Luke.  Interesting build, subscribed!!!
Escy
Nice, I had plans of doing something similar but wanted to use a Saab B204 but i've gone in a different direction (Audi 2.7 bi turbo into a Porsche Boxster S).
Are you going to run an LSD? Any pictures of the gear linkage?
tomaky
What on earth made you do that ecsy?
Westfield Seiw
Ex - 2003 Sable
Lord SanDisk
Ha! not sure if it is LSD are the T5R LSD as stock?? Need to find that out. and yes I'll post a few photos of gear linkages and some more detail ones shortly, just in the process of replacing wishbones.
And you could call it ecsy haha! Nah I love the sound and feel of a 5 cylinder engine, I love turbo noise and I'm a massive believer in power to weight! so it suits me  s:) :) s:)
Escy
Quote from: "tomaky"What on earth made you do that ecsy?
Huge power potential (i'll be aiming for around 500bhp), far more reliable than the Porsche engine and a fraction of the price for a replacement engine if ever needed.
I'm looking forward to seeing more pictures, I do like a 5 cylinder Volvo engine. Someone on a VX220 forum fitted a Focus ST 2.5 engine into one.
Lord SanDisk
This is the same engine, the 2.5 T5 is just a bored 2.3 T5 with plastic intakes, different injectors and rev friendly turbo.
2.3 T5 is just inherently stronger! ready for more boost  s;) ;) s;)  just those pesky rods that need changing as cant have boost below 3k rpm or they bend like cheese - I'll get some more detailed photos up tonight.
MR TWO
Great!
This swap looks excellent. Would love to see the detailed stuff. Very impressed that you managed to fit a 5 pot in and got the box in as well. Keen to hear whether that box did have an LSD.
Love the sound of the 5, wouldn't mind one of these swaps myself.  s;) ;) s;)
Jrichards20
Quote from: "loadswine"This swap looks excellent. Would love to see the detailed stuff. Very impressed that you managed to fit a 5 pot in and got the box in as well. Keen to hear whether that box did have an LSD.
Well we know what's swaps going in the current one then!   s:mrgreen: :mrgreen: s:mrgreen:
Street Triple 765 RS
Lol, I am tempted Josh!  s;) ;) s;)
s12vea
Seems like an pukka conversion.
Do it Nigel!!  s:) :) s:)
TF204 Blue
Another one won't hurt  .....
Nope if you have to notch the subframe it has to be a V6
SuperArt
The 'almost v10' soundtrack of an i-5 sounds better than a V6 imo   s:? :? s:?
It's a tough call.
Best regards,
Arthur
s12vea
They have a lovely sound and plenty of easy power upgrades.
TF204 Blue
