Braces
Started by Carolyn, September 24, 2019, 08:46
Just to say, I'm gauging interest in another batch (6) of front braces, and a batch (6) of our version of a TTE ('Matt') under brace.
If anyone has an interest, please say so here.  Also say which one you're interested in.
TTE brace please.
Mine has seen better days.
Not interested but chapeau for the initiative!!!
igla
Awesome, I want both.
TTE brace please. Mind is well past best as well.
househead
Interested in both of these projects!
steveash
Would be very keen on completing the set with an under brace.
J88TEO
Hi,
I have a 2004 mk3 so am interested in both.
Thanks.
igla
Hello, what's up with these, do we have enough potential stiffeners? :)
Quote from: igla on October 17, 2019, 18:12Hello, what's up with these, do we have enough potential stiffeners? :)
Very nearly.... please don't forget this is not exactly a business!  I do them in batches to keep costs down.
I'm planning on making the under-brace out of 20x40 steel box section..  I now have to price it up and check availability of stock.
Then I'll put a price out there and you guys cab decide if that's going to be ok.
Ok.  Jig built.  Prices for materials and powder coat and.... obtained.
The price is: £150 including a £10 donation to the club.
Please let me know if that's OK and you want to go ahead at that price.
They will be made from 20mm x 40mm box section steel.  With a better central reinforcing structure than the TTE/Matt brace version.
househead
@Carolyn Will the mid braces fit in addition to a Corky/Snelbaard breastplate? I know I asked this question before with regard to the Matt/TTE brace but as yours won't be a completely direct copy I thought it might be worth confirming.
It's a go from me!
Quote from: househead on October 22, 2019, 13:32@Carolyn Will the mid braces fit in addition to a Corky/Snelbaard breastplate? I know I asked this question before with regard to the Matt/TTE brace but as yours won't be a completely direct copy I thought it might be worth confirming.
Should not be an issue as they it will be the same depth as the TTE
I've ordered and paid for the steel and other bits needed.
I do hope all of you who said you want one still do!
Quote from: Carolyn on October 22, 2019, 17:47I've ordered and paid for the steel and other bits needed.
I'm not going to let you down am I?
I know that consequences :)
Snelbaard
Dift
Carolyn,do you have a link for the front brace? Is this a strut brace or underbody?
Quote from: Dift on October 22, 2019, 19:20Carolyn,do you have a link for the front brace? Is this a strut brace or underbody?
This is an underbody brace.  I need a little more interest to do another batch of strut braces.
Link for strut brace:
https://www.mr2roc.org/forum/index.php?topic=67481.75
Quote from: Carolyn on October 22, 2019, 13:40
I am going to get dimensions from Snelbaard for his breastplate, map it out om my jig and find out about compatibility for sure.  I'll let you know.
Quote from: Carolyn on October 23, 2019, 09:02I am going to get dimensions from Snelbaard for his breastplate, map it out om my jig and find out about compatibility for sure.
I am in awe.
Chapeau!!
Seriously; the coöperation on this club (of which this is a cool example) really is .... well, níce.
Thank you for this cheerful ´start´ of the day. Between brackets because that was at 06.15 but just had my first coffee of the day so my brain is getting the message too.
Many thanks to Boris for sending dimensions.
It will be 'snug' but it is all compatible.
Might as well all pull in the same direction!
househead
Excellent news @Carolyn
And great work by yourself and Boris for providing top quality braces for us all to enjoy
Well.... To be SURE.
I put the car up on the ramp and re-installed the Mattbrace.
As things stand they are not compatible.  Either the reinforcing strips on the Breastplate would have to be notched or the new underbrace wound have to be packed to sit lower, less than ideal as the brace is already the lowest point of the car.  I don't think removing sections of the breastplate reinforcement would have a major effect on its rigidity.  I could also supply packing plates for the underbrace to give clearance, but it will then be sitting 10mm below the chassis rails.
Bugger.
househead
Another 10mm lower would def be a problem for me. I get the odd scrape as it is (30mm lowered springs).
Would still be interested in the front lower brace for sure.
