17 " Alloys
Started by Anonymous, March 14, 2006, 18:42
Hi, could anyone tell me if the following will fit OK my 2002 MR2 (not lowered).
17" Hi Octaine X-Dynamic alloys 7"JJ, ET40, currently fitted with 205/40's (obviously I'd change two for wider for the back).
Cheers, Nathan.
should do
you also require the wheels to have a 4x100 pcd.
Richie
Thanks, tried fitting them but the fronts rub on brake calipers. As they are ET40 could I fit 5mm ?, presumably this would then make the offset 45 ?
LeeUK
IIRC it goes the opposite way, therefore it will be 35 offset.
[size=100]JELBE[/size]
[/color]
romoby
Quote from: "morkster"Hi, could anyone tell me if the following will fit OK my 2002 MR2 (not lowered).
Cheers, Nathan.
Yes....you can fit without problems.
