MOT Pass with exhaust leak and CEL :)
Started by edward.carter, April 21, 2006, 18:00
edward.carter
Cat flexi joint below manifold is currently leaking
Pretty sure CEL is faulty 3rd (post cat) O2 Sensor
so on with the results...
Engine Temp = Warm
Fast Idle Test
Engine Speed 2500-3000rpm mine=  2973rpm
CO max 0.2%     mine =                     0.01%
HC max 200ppm            mine =          16ppm
Lambda 0.97-1.03                mine =    1.01
Natural Idle Test
Engine Speed 450-1500rpm      mine = 756rpm
CO max 0.3%                    mine =      0.01%
  s:D :D s:D    s:D :D s:D
