Bosch LSU4.2 wideband o2 sensor
Started by kanujunkie, September 23, 2006, 09:29
Yes, the Innovate LC1 has a 0-1 NB and 0-5V WB output.
Its Bosch LSU sensor is also PnP compatiblity with the stock turbo Beetle sensor and is available for < $USD50 from any VW dealer.
Many dyno's use the Innovate technology which means their WB controller will plug right into your WB sensor.
Much less fiddly all around.
#51
PnP? You mean there's no socket wiring required? Wow, that really is good value.
Quote from: "wts"Yes, the Innovate LC1 has a 0-1 NB and 0-5V WB output.
(as delivered fom the factory, but both programmable to whatever you need using the LM-Programmer software)
Quote from: "spit"PnP? You mean there's no socket wiring required? Wow, that really is good value.
Correct. No splicing/cutting or any other mucking about with wiring.
 m http://www.spyderchat.com/phpBB2/viewto ... rbo+beetle m
