Would sparco seats etc fit in 06 reg easily
Started by Anonymous, October 30, 2006, 20:23
I have decided to keep my car and am going to mod it slightly as I am a bit bored and wish I'd got some swizzy interior!
I really want some blue and blk sparcos or similar
Thanks for any advice you can offer
Depends on the seats in question: A lot of aftermarket ones won't fit due the relatively small cabin we have. Also, you'll need to make up some custom brackets for them to bolt onto, as (AFAIK) no-one makes a set for the '2.
scottish_turbo
You buy the seat and the base adaptor for the seat to fit to the floor of the car.
This is the fitting instructions -
http://www.sparcousa.com/resourceFiles/20.pdf
application guide -
http://www.sparcousa.com/resourceFiles/30.pdf
seat dimensions are available on the website too
there is listings for the mr2 roadster on here.
davidhowson
If you do swap for some sparco / OMP / Recaro and you want to sell your standard seats, let me know!! - David
been looking at this myself due to the 'two' having a cream leather retrim, not my cup of tea to br honest
biggest issssue  is making sure they aren't any higher than teh stock items.
if someone can find seats and brackets that do that out of the box, I'd be interested.
dieamond
Quote from: "markiii"if someone can find seats and brackets that do that out of the box, I'd be interested.
I have !
 s:-D :-D s:-D
TRD - Cusco - C-One - Tom\'s - Amuse - Top secret - Veilside - Spoon - Blitz - Invidia
JUN - Racing Gear - APR Performance - HKS - Apexi - Project Mu - Trial
going to share then Arnaud?
dieamond
How much were they mate?
dieamond
You need :
- Bride rails, 350 Euros for the pair
- If you take side mounting seats like me, 2 fixations, 80 euros for the pair
- Roadster 2 seats, 500 euros each
Total : 1430 Euros
ouch, there goes next years bonus  s:-( :-( s:-(
so they are definately no higher than stock?
dieamond
Quote from: "markiii"so they are definately no higher than stock?
nope
driving position is different, but it's very good and I'm not higher
if you take bottom mount seats, like sparco milano you should sit lower than stock
thanks,
If I do it though I would likely go for thsoe same seats, being toying with it since I saw Franks in his MK2 at JAE
dieamond
Quote from: "markiii"thanks,
OK
Maybe you should look at the different Bride rails, those are MO type, but there are some dedicated to side mounting, like the RO
Quote from: "dieamond"
nope
How's the comfort level compared to stock  s:?: :?: s:?:
dieamond
I use my car every day
I have done 300km to go to the track a friday, 200km on track saturday and 300km to come back from the track the sunday
I find the confort ok
For me confort is more a question of position so it's fine for me.
Can you supply all these items Arnaud? Are the prices you have quoted for buying them through MRS Passion? Thanks  s:) :) s:)
dieamond
Quote from: "SteveM"Can you supply all these items Arnaud? Are the prices you have quoted for buying them through MRS Passion? Thanks  s:) :) s:)
yes I can supply them, and yes I can sell them to you at this price
I have a correct rebate @Sparco
Add 60 or 70 Euros to ship the whole big package to UK thought  s;-) ;-) s;-)
Arnaud, do you have teh bride part numbers? I'd like to add this to teh library
dieamond
Quote from: "markiii"Arnaud, do you have the bride part numbers? I'd like to add this to the library
T051 and T052, don't remember which one is left and which one is right
To this part number, you add the type or rail you want, ie T051MO  :-) :-) :-)
 m http://www.tees-usa.com/seatrail.html m
nope
Arnaud I thought I had read somewhere that the Roadster seat could be  either base or side mounted? If so do you think it could be made to fit even lower than stock by base mounting it? Also were the side mounting brackets that you used Bride or Sparco parts?
dieamond
OK, it won't be easy for me to explain in english, I'll try thought
Bottom mount seats (Sparco Milano for example) base is flat
So you just put them on the rails, put 4 bolts and you're done
Full buckets, from Sparco Evo to Sparco Roadster have a curved bottom
If you side mount them, you have to put them 3cm above the rail, which is generally the side brackets lowest settings
To bottom mount them, you need to up them using an "high mount kit" like this :
I hope I'm clear  :-) :-) :-)
That's great Arnaud I understand fully  s:) :) s:)
I think I have well and truly placed this task in the "Too difficult box!"
