advice needed for Spraying Car parts!
Started by rtbiscuit, December 17, 2006, 23:57
rtbiscuit
am looking into spraying the inside of my lights body colour to match the car, and hopefully some headlight eybrows as well.
my car is blue, and i believe this is a metallic paint.
would i get away with doing this my self, have done some spray work before and i'm not to bad. but it will be an out of the can jobbie.
i have access to a small spray booth, and i know the prepwork is important to very fine grade wet and dry to get the smoothest finish etc.
i know i need a plastic primer first to make the paint adhere, and then undercoat, then build up lots of thin light coats, lightly sand in between.
after that i'm not sure if i need to laquer or not.
and then leave for a length of time. the head lights will be fine to fit after 24 hours as they are sheltered. the eyebrows i will leave in a warm place for at least a week, or can i bake them on a low heat in an oven.
so to sum up:
1 should i do this myself
2 if so any tips hints or directions
3 do i need to laquer it, iv heard metalic paint can be a git to use.
4 where is the best place to get decent 8m6 paint
5 any undercoat colour recommendation
Dev i know you do some of your own spraywork so advice from you would be greatly appreciated, i'v seen your work already and in the blue, so you are a man of experience! same goes for anyone else with spray experience etc.
cheers in advance
current car: Jaguar XKR
Previous cars:
You can do it yourself, as long as you take care, and I'm sure you will.
Its a two coat application, so you will need a clear lacquer layer to finish.
Small parts shouldn't be too difficult. You may be able to get the paint from Mr T, or maybe one of the ebay guys. There is usually somebody on here who knows where to get the best paint in a can.
 w www.paints4u.com w     s:wink: :wink: s:wink:
not cheap but great quality and better spay pattern nozzles on cans than halfords cheapo ones
Ace Perry, that's exactly what I had in mind.  s:) :) s:)
rtbiscuit
Sorry to reserect an old post but it all kind of follows on.
got some bits arriving soon for spraying, headlight eyebrows and TTE rear bumper inserts.
am spraying them in 8M6 lagoon blue.
my questions are:
recommendations for undercoat colour? should i use grey, or white, or does it not matter, and i could use red?
the website above doesn't seem to specify car colours, and only seems to come in tins. i need aresols. so any ideas
i have found this site
 m http://www.auto-paint.co.uk/SHOP/index.html?c42.html&1 m
anyone used them "do they seem kosher"
or is there somewhere else for air-arseol   s:wink: :wink: s:wink:   paint cans
cheers peeps
Previous cars:
Peter Wright
Quote from: "rtbiscuit"recommendations for undercoat colour? should i use grey, or white, or does it not matter, and i could use red?
None.
Use spray glue
Will tell you the name when I get home from work
primer, grey or white will do, if in doubt use white
the above site I listed does do spray cans matey  s;) ;) s;)
 m http://www.paints4u.com/ProductDetails. ... uctID=5021 m
rtbiscuit
doh!
any recommendations on grade of wet and dry
Previous cars:
rtbiscuit
i'm guessing 2 cans should be enough for 3-4 coats on headlight eyebrows and TTE rear inserts
Previous cars:
2 cans will be plenty bud, around 12-1400 grade for between coats
also you can use the spray paint for stone chips, spray it into the cap, let it thicken/dry slightly and use a small artists brush, gives a much thinner coat than the horrible touch up brush kits that leave a 'hump'    s;) ;) s;)
rtbiscuit
does it matter which lacquer you use, as i have some laquer allready.
Previous cars:
as long as its cellulose or acrylic based , no probs matey
is it halfords?  if so then fine.   theres not many that are not ok to be honest
rtbiscuit
how many coats of primer would you do, i think 2-3
Previous cars:
as long as its fully covered then thats enough primer, you dont need to layer that, its only to get a good key for the main paint to take hold of
rtbiscuit
just spent £45 on all bits
got myself:
plastic primer
Grey Primer
2 Cans 400ml 8M6
Can gun
and wet and dry.
not to bad got enough stuff to hopefully do headlight eyebrows, TTE rear bumper, and Valve cover.
am looking forward to this.
Previous cars:
enjoy matey  s:) :) s:)   its always better when you do it yourself  s;) ;) s;)
ps  they do plastic primer in grey or white, so no need for a further primer  s;) ;) s;)
rtbiscuit
have started, and undercoated the parts,
just about to put first coat of colour on,
advice being seeked is, when sanding between coats do you use the wet and dry,   .........  wet or dry ?
Previous cars:
pretty sure its dry
but dont rub too hard as the heat will build up and knacker the undercoat
rtbiscuit
got some 2000 grade
Previous cars:
ultimately at this stage wet or dry will suffice, tho I do tend to go with wet
once you have the colour on then go wet not dry   s:) :) s:)
rtbiscuit
cheers perry,
have started a guide on here as well, work in progress.
Previous cars:
rtbiscuit
perry in reference to laquer, just found the can  s:D :D s:D
its silver hook and its arylic based, is this stuff on your recommend or bin list   s:wink: :wink: s:wink:
Previous cars:
Acrylic should be fine as it mates happily with most paint finishes
might be worth spraying a bit of colour onto a scrap bit of something, let it dry and then give it a coat of the lacquer, nothing worse than when it all bubblew/wrinkles up due to a reaction.
rtbiscuit
just laquered the parts and left them,
have noticed that i didn't get my laquering quiet right, moved to quickly, and have got a slight orange peel effect.
 m http://www.mr2roc.org/phpBB2/viewtopic.php?t=14870 m
am going to let it harden off, i'm guessing this will require a light sanding with my 2000 grade and another coat of laquer.
or can i t-cut this effect out,
any suggestions.
Previous cars:
