SNOW!
Started by Anonymous, January 14, 2004, 13:13
Quote from: "markiii"Though we could possibly tap a relay off the heated rear window switch?
Now that would be good - hit the rear demister and the mirrors turn on too.... good thinking batman!   s:D :D s:D
Quote from: "krisclarkuk"
Thats exactly how my Santa Fe works.
sorry victor, being a bit dense here. I assume a Santa Fe is a car?
Quote from: "markiii"sorry victor, being a bit dense here. I assume a Santa Fe is a car?
I guess you could call it that. I call it "The Beast" as its big ugly and always thirsty! Its a Hyundai SUV. Good for the snow, bad for the pocket.
filcee
Quote from: "victor"
Ditto the Leon, and I think the Ibiza before it ...
Phil
2003 6-sp SMT in Sable
Quote from: "markiii"The only stumbling block could be where the time circuit sits? Unless Jon is going to tell me that they stay on until you turn them off something must control how long they are on for. If it's a function of the body ECU we'll be stuck.
works off the hrw switch in the Celi!
...but how's it gonna un-freeze my squirters  s:?: :?: s:?:    s:) :) s:)    s:| :| s:|
relay it is then.
Quote from: "Jonny Turbo"
Why not take a look at how some other cars deal with this?
My initial idea would be to enclose the water pipes in some form of thermal insulation and heat this internally with a heated wire wrapped around the water pipe inside the insulation. I guess a couple of watts would suffice.
A second idea would be to tap of some warm (hot) water from the radiator feed and put this through a pipe running parrallel to the windscreen water pipe.
As for the squirters, be get a couple of heated squirters from another car, such as the VW Golf. I dont know whats available that would fit.  BUT maybe if the water in the pipes was heated enough, then the squirters would conduct enough heat to free them up?
The hot water solution I think would be easiest to do. Any engineers here who could develope this as a club project????
There is a relatively easy way to fix the squirters in the winter, but could be a little more expensive than usual. If you use NEAT screewash, it SHOULD protect it from feeezing down to about -10 degrees. What is says on my bottle and so far, so good. It hasn't frozen. Change the ratio of dilution as the year goes on and it shuld even itself out cost wise over the year......
Chris
I can feel a 'club-mod' feeling coming on!!!  Luckily, my drive gets hit by any morning sun, so i've not previously had any problems with the jets freezing (only when the water hits the window, freezes and makes it worse!   s:x :x s:x  )
What do they do in really cold places?  Maybe Tem has an answer...
[size=100]
Ex 2003 Astral Black 6sp SMT
Ex 2002 Lagoon Blue 5sp MT
[/size]
eskimo he pee on bonnet  s:D :D s:D
filcee
#36
knackers forward visibility tho'   s:D :D s:D
Phil
