Cone Air Filter for AEM
Started by uktotty, February 3, 2009, 17:17
Any idea what make/size this cone filter is, does it need to be AEM etc?
I seem to have dented it when I hit the wall backwards?
it will still be ok dented, that said if you want to change it I'd use teh chance to upgrade teh filter element to an APEXI, which will give better filtration
custardavenger
Can you measure the pipe that goes into it? Should be all you need for a replacement as the AEM is quite long.
Project Custard Clicky
Cheers guys will check the opening and also look into the Apexi option
