MOT Failure :(
Started by uktotty, May 15, 2009, 14:50
Just got a call from the garage, I have failed on rear disks, rear pads, front pads and there is a 9" crack in the windscreen which I swear was NOT there at 8.3 this morning!
So disks and pads? What would you recommend?
WE HAVE FOR SALE A FRONT AND REAR SET OF 40 GROOVED PERFORMANCE BRAKE DISCS AND EBC GREEN PADS FOR THE CARS BELOW..
TOYOTA MR2 1.8 VVTI ROADSTER 2000-ONWARDS
FRONT DISCS ARE 255MM X 30MM VENTED 4 STUD // REAR DISCS ARE 263MM X 22MM VENTED 4 STUD
FRONT EBC PADS DP21295 REAR EBC PADS DP21107
£250?????
I first thought that they were the discs that Nathan has on his car, work well, though they do make a sizzle/rattlesnake noise when warm. Work extremely well with stock pads. Look like good value with pads as well, though I have no experience of Green pads myself.
(edit) Nathan has the grooved and dimpled EBC discs, but still jolly good.
Chris_h
Think Ste and Nic have those
Dare say they will be along in a mo to profer an opinion
I have had them on the front for 12 months. Very good.
Having said that when I was under the car at MOT time the outer edge of the rear face was definetly showing rust marks. Whether its the start of something worse, I don't know, but I think I'll have a look sometime to see if everything is OK.
I like the Greenstuff pads - many don't. There is nothing wrong with OEM pads & they last well.
EBC disks seem to survive the weather better than OEM.
Don't forget to notify your insurers if you're switching to non-stock   s:wink: :wink: s:wink:
Bottom line, these things are life-savers - If t'were me i wouldn't faff about saving 20 or 30 quid on anything generic through fleabay. JMHO.
Looking at that ad description again and reading it more carefully, I realise that its only the pads that are EBC, not the discs. I would go for some that I know I think, or at least ask who makes the discs.
Prices seem to go from £100 for 2 sets plus pads to £480 for Black Diamond!
HELP!!
northernalex
braking.co.uk will give you a good quote for OEM discs/pads if you're interested.
evileye_xc said:
Black Diamond discs are very good Russ if you can hack the price and fancy an upgrade. Pop them on with some stock pads and you'll have a great setup.
Quote from: "northernalex"braking.co.uk will give you a good quote for OEM discs/pads if you're interested.
Cheers Alex
Sent them an enquiry
NickNJ
I've had Green stuff on elise and they were trucking awful!! EBC turbo grooved discs are really good and maybe mintex pads are a good bet for reasonable budget.
Black MR2 Roadster
I bought these with Greenstuff pads for £200!!
Thats a good price,where from?Delivered?
on eBay with £9.99 deliv
custardavenger
Good deal there Russ. It's a shame you have to fit them straight away or I'd get them plated for you
Project Custard Clicky
Disks and pads arrived today, time to get fitted and get a MOT
All sorted, MOT passed today  s:) :) s:)
HUGE thanks to Custard who came over at 10.30 last night with the windback tool and left at 1.40am after we upset the neighbours.
