AEM gauges installed
Started by VVT-i, November 2, 2010, 16:54
VVT-i
I got a couple of new gauges the other week and took the car over to Stainless Creations (Falkirk) to get them fitted today, very happy with them and far better quality than the cheap Autogauges that were in place before, the reason for the change was because the pressure gauge stopped getting a reading, I tried a new sender but it made no difference so I deceided to get the AEM gauges fitted. After a bit of faffing about to see what the original problem was (and to make sure all was ok with the car) it turned out to be a broken wire hidden behind lots of other wires behind the dash. All fixed, new gauges installed, what do you think of the new look?
Before
After
2005 MR2 Roadster  (Black)
very nice Davy
I've also got AEM, for boost and AFR, so ran out of room for both oil temp and pressure.
Got a double SPA for that, spoils the symmetry a bit, but at least got all the readings now.
Looking sweet Davy. AEM produce some good stuff.
