Will a "W" reg hardtop fit a "02" reg?
Started by Trajara, July 22, 2012, 11:28
Trajara
Just been to look at a hardtop for sale locally, the sellers MR2 has black brackets positioned behind the drviver & passenger seats that the hardtops clamp onto, our MR2 doesn't have these brackets or do they come off the sellers car to accompany the hardtop?
 Really confused now........................   s:?: :?: s:?:
Every hardtop will fit every car.
remove that kit and put it on your car
You also need the two rear chrome brackets off the sellers car.
You can trim your own plastics for the side strikers, or simply swap plastics with the seller.
Also get the demister cable.
View this for the list of parts for fitting.
 l viewtopic.php?f=46&t=13446 l
Trajara
Quote from: "M R 2"You also need the two rear chrome brackets off the sellers car.
Thanks so much for this link it's a great help.
If you get stuck, or lack confidence, give me a shout. Ill pop out and give you a hand. Dont forget the T30 torqs tool bit to remove the chrome brackets.
Trajara
Quote from: "dick2ski"If you get stuck, or lack confidence, give me a shout. Ill pop out and give you a hand. Dont forget the T30 torqs tool bit to remove the chrome brackets.
Thanks d*ck, you're a true gent   s:D :D s:D
