washer jets.
Started by Pavett1990, March 21, 2013, 17:32
Zonda_
#50
Quote from: "Pavett1990"
Quote from: "Zonda"How will you cope when ours are all 267  better than yours?    s:D :D s:D
than mine?
i have some on order in the post haha
Quote from: "Wabbitkilla"Must admit in current weather I wouldn't mind some heated jets like on my Audi, four jets with heat   s:D :D s:D
now that sounds cool.. donor car?  s:lol: :lol: s:lol:
No, than the v40 ones!
2001 Roadster, che manifold, 40mm lowering springs, BMC Carbon intake mounted behind battery.
Pavett1990
#51
ahh yeah.. i think i will be the 1st oerson in history to say we will be superior with our peugeot parts   s:scared: :scared: s:scared:    s:crazyeyes: :crazyeyes: s:crazyeyes:    s:lol: :lol: s:lol:
thestig84
#52
Well for anyone is near Crawley, Bridges has plenty of volvos and pugs with them still fitted. I just like the squared off Volvo ones a bit more to look at. Very cheap from the scrappy too   s:wink: :wink: s:wink:  !!
Zonda_
#53
All the scrappies up here charge a minimum of a fiver so I'd rather buy new.
ais
#54
Can someone write this up in the how to section so future 2 owners can benefit   s:lol: :lol: s:lol:
Pavett1990
#55
When mine arrive I will compile a how to on fitting and give description of which ones to buy
dj2k21
#56
Here is a guide on how I did mine
1. open bonnet on mr2
2. Pull off hoses fron each washer jet
3. Push the washers out of the hole or pull them out from the top if u prefer
4. Push the new washers into place, should click into place and feel solid
5. Reconnect hoses to washers
6. Close the bonnet
Done  s:) :) s:)
Quote from: "dj2k21"Here is a guide on how I did mine
6. Close the bonnet
Done  s:) :) s:)
I'm going to have to pay a garage to do that for me  s:) :) s:)  hehehe
dj2k21
#58
Haha I sure hope not lol
Zonda_
#59
Quote from: "shnazzle"
6. Close the bonnet
Done  s:) :) s:)
One thing missed from that list that I found when I removed mine a couple of days back is that I needed 2 flat bladed screwdrivers to compress the clips on the underside of the jets before they would come out of the bonnet hole.
dj2k21
#60
Oh no I just pushed mine out and the clips compress naturally as u do it I found
Zonda_
#61
Mine wouldn't I nearly broke my bloody finger!
dj2k21
#62
Ahhh that will be because I take mine out when I polish and wax the bonnet so they will be easier than yours which I guess wont ever have been out before?
kentsmudger
#63
Ordered some for mine too!
Arrived today. A nice job for the day off tomorrow. Will post pics
Pavett1990
#65
Mine should be here Tuesday now then?
Zonda_
#66
Quote from: "shnazzle"Arrived today. A nice job for the day off tomorrow. Will post pics
Yep mine too.
Pavett1990
#67
As it turns out mine came yesterday and the missus put them aside and forgot to mention that they were here
mr mr2
#68
Got mine to day some thing to stick on the car tomorrow as long as it is Easier than putting on my manifold lol
Excelsior
So yeah they don't fit  s:) :) s:)
Need some DIY to get them to sit properly.
Also, mine spray downwards, which I hope I can adjust by sticking a small screwdriver in the hole and pointing it upwards.
The clip is far smaller than the original.
Also, the original has a 90 degree bend in the pipe connection. So on these, the pipe sticks out downwards. Should be ok, but it is a bit tight.
Had to use a screwdriver to push in the clips quite hard to get the original sprayers out
Pavett1990
#70
Quote from: "shnazzle"So yeah they don't fit  s:) :) s:)
can you let us know how you got them to stick? and if your able to angle the mist?
thanks
ash
thanks
ash
Will do when I give it a proper go.
Going to have to pull it back off and replace with stock one until I can think of a solution.
One easy solution is glue or tiger seal.
A more elegant solution would be to use a thin washer.
I will keep you updated
Pavett1990
#72
great stuff im having a look at mine on sunday
Yeah Im not impressed. I can't get it working.
They simply don't fit and it'll take a grommet of sorts to make it fit.
The jets are poor with an odd spray pattern.
And they're matt black which looks naff on my black car.
Left new. Right original. Totally different size of clip.
Hole shape
Who's taking on the challenge?
Pavett1990
#74
do you think they will fit with like tiger seal or a dab of something?
is there any chance you could get a photo of the mist spray working?
