Front & Rear Strut Bars
Started by Peter Wright, June 19, 2004, 21:12
Peter Wright
I have been looking for the above to minimize the scuttle & shake
However I was talking to my local engineering shop who has made them before for stock cars etc & he says he can do them for about £50 each
He then asked,   "do they have to be spring loaded or not,"    not knowing what he was talking about I said, "I would find out"
So do they or not or does it not matter
Or any other questions I should ask him
Pete   s:? :? s:?
Do you not have the antiflex plate as that helps quite a bit.
SteveJ
As Kris says, the anti-flex plate is probably the best solution for scuttle shake as it reduces the amount of twist in the floor-pan.
For out & out improvement to handling, the first thing I would fit is a front strut brace.
Rear strut braces IMHO are a waste of time as they only reduce the movement between the turrets by about 0.5mm (someone on SC a while ago measured nearly 5mm of movement on the front turrets without a strut brace  s:? :? s:?  with less than 1mm once the FSB was fitted - the stock RSB seems to do a pretty good job allready with negligable gains available)
SteveJ
PS. They dont need to be spring loaded - a solid bar is fine.
Quote from: "SteveJ"PS. They dont need to be spring loaded - a solid bar is fine.
What does spring loaded mean anyway?
Peter Wright
Quote from: "Tem"
I dont know Tem thats one of the reasons I posted
Pete   s:? :? s:?
