Work ongoing.
Started by Mike_V, May 31, 2013, 21:22
Mike_V
Hoping to get the steering rack and power steering pipes that I refurbished fitted tomorrow, change of mind means a lot more changes to come.......
2004 Red edition in Sable.
s12vea
What exciting changes are these Mike?
TF204 Blue
Another one won't hurt  .....
Mike_V
Didn't say exciting but I'll post when all done  s;-) ;-) s;-)
s12vea
Will look forward to seeing the "not exciting" bits  s;) ;) s;)
TF204 Blue
Jandaw
Saw the pipe work in the flesh. Lovely job. I take it you managed to undo that obstinate fitting.
Mike that is just a work of art mate. Well done.
Two's Company
Where did you get the fittings for the pipes? I true to get them from pirtek but they couldn't get them.
Mike_V
Got them from an ex member  s;-) ;-) s;-) . Sanded them down, sprayed with 2 coats of primer, 3 coats of finish colour then three coats of Plasti-Dip rubber coating.
I need this. My power steering seems to show a bit of a leak. How much does such a new assembly set you back?
If you were to buy the pipes on their own they would cost you £249+vat.
Don't know the price of the rack.
Eek!
Starting to think it may be an idea to get rid of this car, cut my losses and try again on a nice facelift
Mike_V
Well. Didn't get the steering rack fitted due to last minute issues that needed to be tended to so didn't have enough time, decided to continue bringing the front end up to spec though and got this done.
FGrob
Nice one Mike - you are getting as bad as me.  s:lol: :lol: s:lol:    s:lol: :lol: s:lol:    s:wink: :wink: s:wink:    s:bowdown: :bowdown: s:bowdown:
Mike_V
Finally got the steering rack fitted and only some touch up required now.
Mike_V
After getting all this done and the suspension problems that I had, had a good run out in the South Lakes area today and the car felt fabulous. My local garage who did my alignment (again) said bring it back in two weeks and we'll re check all of the torque settings and tracking again free gratis, now that's what I call service  :-) :-) :-)
Fine result Mike. Looking good.
Sounds like you've found a good garage there   s8) 8) s8)  Which of your locations is it local to?
Mike_V
Westgate Tyres in Morecambe, they're young, enthusiastic and take pride in their work. They're not just tyre fitters but all trained mechanics, they've become friends and I can't praise them highly enough.
Wow, I was using them back in the days of the mullet   s:D :D s:D . They've always had a great bunch of mechanics on hand there. Glad they're still going strong.
Mike_V
Drained my catch tank after a couple of thousand miles and there wasn't much in it, just a bit of dark fluid smelling of fuel/oil and no condensation at all, don't know if this is a good sign or not!
Mike_V
A job I've been meaning to do for some time, took off the ABS Actuator and bracket and this is what I found, probably common to most "2"s now.
New bracket duly waxoiled.
Actuator tidied up and fitted, ready to back on tomorrow.
s12vea
Much improved mike
TF204 Blue
shep1975
Wish I had the skills to do this kind of work myself. Lovely job.
Markb
Worth checking the pipe work and the rack tube for for rust....i had the covers off doing an oil and filter change,noticed some minor rust,painted the rack tube and cleaned the pipes up,put a light coating of grease on the pipes and covered them with black split conduit tubing,it actually looked quite good  s:lol: :lol: s:lol:  i actually did the same with the Rav4 a while back and it seems to protect the pipes well.
Mike_V
All done  :-) :-) :-)
