Sat Nav
Started by Peter Wright, July 6, 2004, 21:59
philster_d
#75
Well there is such a thing as a nav pod that fits there, not sure its hideable tho.
I see what you mean would be quite good if not trace was there to be seen.
Philster.
#76
Quote from: "gun41"- Has anyone installed a tom tom go in the dash auxiliary box?
I hate seeing any cable and think it would make an ideal permanent dock without being on show to potential thieves
Just lift the lid of the auxiliary box when you want to use it
Just need too find somewhere else for the shades - that's all keep in there!
So, design one, if you use some squirty foam and plastic bag, you can make a mould of the area, then carve it out to your design, recreate that in normal foam and fit, as for a finishing cover, speaker aucoustic carpet does really well. would be really easy to create a home for the Tomtom and a small compartment for the sunnies
philster_d
#77
Does it fit in there or will you need to recess the dash inside the compartment ?
Quote from: "kanujunkie"if you use some squirty foam and plastic bag, you can make a mould of the area, then carve it out to your design, recreate that in normal foam and fit, as for a finishing cover, speaker aucoustic carpet does really well. would be really easy to create a home for the Tomtom and a small compartment for the sunnies
Resourceful little bugger aren't you? You should be an engineer.......  s:wink: :wink: s:wink:
