How ill fit my new breastplate
Started by redarrow, August 17, 2013, 15:46
redarrow
How i fitted corky breastplate.
the 6 bolts needed are there from
The stock plate and stock bar.
Jack car up both ends straight.
Release the three plastic grommets with pliers.
Release the 4 bolts 12mm socket of the plate , now put that plate aside
Know release the bar on the other end two bolts 12mm , put that aside
Position the new breastplate where the plastic grommets are ,
Push the breastplate into the plastic grommets.
Know screw all the nuts in position then
Do all the nuts up randomly, until the
Breast plate is touching the car floor tightly.
Make sure it all straight.
Take car off stands enjoy your ride.
Hope it helps someone in the future.
[size=85]These are the dreaded code your get with cheap 02 sensors.
P0135 drivers side position. (o2 sensor heater malfunction (bank 1 sensor 1)
P0155 passengers side position. (o2 sensor heater malfunction (bank 2 sensor 1)
P0141 passengers side down below exhaust position. (o2 sensor heater malfunction (bank 1 sensor 2[/size]
