Zunsport grille question
Started by AndyM, September 7, 2013, 16:56
AndyM
Hi,
Could someone with a facelift front Zunsport grille please let me know where the fixing positions are located? I'm considering ordering one to go over my damaged plastic grille but I want to make sure the new grille isn't going to be trying to attach itself to a broken part of the original.
Please see a picture below for reference of where my damage is if that helps.
Thanks,
Andy
At the bottom on the nearside...
Barney Bear
Hi Andy from memory it has 2 or 3 downward facing L pins at the bottom that just hook over the edge of the bumper
And two screw fixing at the top   s:D :D s:D
54 Sable, Air con, hardtop
trevsmr2
QuoteFitting is straightforward with the grille being located behind the number plate and secured in place by two self-tapping screws at the top and push fit clips to the bottom edge.
AndyM
Quote from: "trevsmr2"
My concern was that the "push fit clips to the bottom edge" might be trying to push onto one of the wobbly bits  s;) ;) s;)
AndyM
Quote from: "Barney Bear"Hi Andy from memory it has 2 or 3 downward facing L pins at the bottom that just hook over the edge of the bumper
Excellent. When I watched one of there fitting videos it seems on some cars their 'push clips' click onto the grille behind so wasn't sure. Cheers.  s:) :) s:)
MisterK
You shouldn't have a problem.  The bottom part hooks behind the bumper aperture and the top part is fixed by 2 self tapping screws.  I used one of the screws to fix one side of my DRL & killed 2 birds with one stone so to speak.
A 2 minute job without the DRL's, a bit more fiddly with them to get them sitting square!
