mr 6 speed different boxes info wanted
Started by 5e colin, April 10, 2014, 12:17
5e colin
hey lads with the 6 speed gearboxes can you  confirm the speeds vs rpm in 6th AT 62 mph for al the different 6 speeds gearboxes you have
very much appreciated
thanks in advance cheers 5e colin
C60  rpm in 6th at 62mph
C63  rpm in 6th at 62mph
C65  rpm in 6th at 62mph
C66  rpm in 6th at 62mph
VF10 POWERED GT TURBO
WANTED C6? GEARBOX
Star_69
You'll need this and this spreadsheet
-Brad
Owner of an \'03 plate "Ship of Theseus" aka Trigger\'s Broom Roadster [strike]1zz-f[/strike]e, [strike]supercharged 2zz-ge,[/strike] 2GR-FE
5e colin
thanks star-69  sadly i cant open the files ( link2  ) crap laptop !!!!!! nead a special program to open it
WANTED C6? GEARBOX
Star_69
Yeah, you need Excel installed.. It's just a handy sheet that works out gear speeds, mph at whatever rpm in whatever gear etc .. What's your tyre size?
-Brad
mrzwei
Spreadsheet from on here:
   Roadster US/Jspec 5 Speed C52   Roadster US/Jspec 6 SMT   EU/UK 5 speed   EU/UK 6 speed   US Celica C60   US Elise C64   Cone Roadster   UK Celica 1ZZ-FE   2003 Celica 2ZZ-GE
First           3.166   3.166   3.166   3.166   3.166   3.166   2.929   3.166   3.166
Second      1.904   1.904   1.904   1.904   2.050   2.050   2.176   1.904   2.050
Third    1.392   1.392   1.310   1.310   1.481   1.481   1.700   1.310   1.481
Fourth       1.031   1.031   0.969   0.969   1.166   1.166   1.364   1.031   1.166
Fifth     0.815   0.815   0.815   0.815   0.916   0.916   1.167   0.864   0.916
Sixth                        0.725                 0.725   0.815   0.916   0.725   0.815
Reverse    3.250   3.250                  3.250   3.250
Final   4.312   4.312   3.941 (LSD)    3.941 (LSD)    4.529   4.529      4.312   4.529
   Tyre width   215   215
   Tyre profile   45   45
   Wheel diameter (inches)   16   16
   Gear ratio   0.815   0.725
   Final drive ratio   3.941   4.312
   Speed @ 6500rpm   142.1087758   146.0051528
   RPM @ 90mph   4156.726519   4045.797739
The data got distorted in the paste so be careful how you read it.
Sixth should read left to right  'blank, 0.725, blank, 0.725'
This I think was posted in the library by markiii.
Ex.MR2 SMT sadly missed.
Star_69
Goto http://tire-size-conversion.com/tire-size-calculator/ and get your tyre circumference in inches from your tyre size
How to work it out using c60 and 245/40/17's (77.6 inchs circumference) as example is:
(6th gear x final drive x mph x 1056) / tyre circumference = rpm
(0.725 x 4.529 x 62 x 1056) / 77.6 = 2770 rpm
-Brad
5e colin
o thanks guys  but its Chinese to me   im only a old school mechanic  s:) :) s:)
i run 185/ 65 / 14" tyres
thanks
WANTED C6? GEARBOX
