SpyderLEE--Widebody gt300 turbo project
Started by Leethesparky, February 8, 2015, 18:22
CrazySX
Quote from: Petrus on January 14, 2019, 18:46
Very cool, including literally, frunk Lee!
I see you have cut outs above the McPherson legs; going to mount a brace? The brace for mine should be here in a week. Already have 20 of the push-thingamies for the frunk plastic. As always; the least important things arrive first.
He ain't see the video has he?? Watch and subscribe to Lee's channel. All will be revealed ;)
Sent from my SM-G960F using Tapatalk
MisterK
Quote from: Leethesparky on January 14, 2019, 11:58
I've moved the power steering pump and the battery. Removed the frunk and ducted up from the back of the radiators to the bonnet vents.
Cut and refitted the plastics to make it look pretty.
Just watched the excellent video of this being created...well worth a watch.  Looking forward to watching the new FL light units being put together...they could add even another dimension to the car  :)
Quote from: CrazySX on January 14, 2019, 18:47
Ok, so no.
As I commented earlier; totally in awe of his get up and go, simply taking on and completing ánything. Just make other choices myself. In this case a brace
Would love to make a vented hood/frunk though. Unfortunatele the Spanish MoT will fail it. They will argument that in case of malfunction fluids from the radiators can get on the windscreen this way. Been there, done that, they did not like it.
Like the idea of the U-rubber. Makes cuts look a lót cleaner. There are also less hefty, way lighter all rubber variants.Used to have an ultra skimpy kind on a roll for use on motorbikes. Forgot all about that! Oh my, I must be getting réal óld  :o
Leethesparky
Cheers, not sure if I'm going to bother with a brace. The struts are so close to the bulkhead I don't think it will make much difference.
Ps does anyone know the proper name for the push clip thingys so I can order some.
MR2 mk3 2001 -- done some stuff to it.
My car thread---http://www.mr2roc.org/phpBB3/viewtopic.php?f=9&t=53643
My YouTube channel---- https://www.youtube.com/c/spyderlee
Dude you gotta get a getting strut brace... It's an amazing mod.
Agreed. Lee it may seem silly but the front brace really does make a lot of difference. The rear one's the pointless one (over and above the stock cross bars)
Quote from: Leethesparky on January 15, 2019, 08:00
A Google for Toyota trim clips will find
https://www.vehicleclips.co.uk/
that have these and many other clips that may be of use to you
Davey P
I think they are called "door trim panel clips" mate
Toyota MR2 Trim Clips
About the strut braces; think of the frunk compatment as a matchbox lower half with the bottom removed.  Two match sticks glued to opposing sides, sticking out below. Now squeeze the sides and watch the ´legs´dance.
The forces on the top support are considerable. Remember thére is where a lot of the forces from the road, the grip, go to. All those forces must be opposed for the construction to be stable.
Action = - reaction.
Adding a brace transfers much of the forces to the opposing side, supported by the road. It is a sort of the one hand shakes the other.
Think of the braces less as reinforcing the box but more as connecting the two legs so forces, action/reaction, can cancel eachother out.
Improved suspension is ever so much more effective when it is well supported.
CrazySX
Quote from: jvanzyl on January 15, 2019, 08:40
Which do you recommend?
I've got an ultra racing one, curves round the brake reservoir. Does a great job, they can be bought for just over £100 brand new(I got mine second hand).
There a loads of brands out there, Cusco etc... But I'd just get what's easily available.
As petrus has said, each upgrade exposes flaws in other areas- I fitted my brace before I had my bushings done and was gobsmacked at the transformation.
Leethesparky
Cheers guys
I'll get some trim clips and look into strut braces. I have to be careful as my power steering pump is there.
Quote from: Leethesparky on January 15, 2019, 13:25
Cheers guys
The ultra racing one will not interfere. It goes windscreen side of the brake reservoir so you should be fine.
Leethesparky
Quote from: jvanzyl on January 15, 2019, 13:27
Cheers guys
Ah cheers I'll have a look
I got some trim clips off ebay, just need to measure up one of your existing ones to confirm the size you need.
I have a DD racing brace which seems to be a copy of the ultra racing design but was a bit cheaper. I noticed an improvement when I fitted it.
Surprised you are not just going to knock something up in your lunch break though!
BahnStormer
I've always just hit up eBay for that and found the right clips within one or two searches.... usually only a couple of quid for a bag of them, incl postage.
Leethesparky
Quote from: BahnStormer on January 16, 2019, 10:41
Yeah I've done the same cheers.
CrazySX
Quote from: Leethesparky on January 16, 2019, 10:42
Or you can just buy something from our Dick Sloan and he normally sticks a bunch of them in with the order complimentary.
Essex2Visuvesi
It's been over a month now..... must be time for a repaint  :D
Cheers guys
Any progress on that front?
Leethesparky
Quote from: Petrus on January 24, 2019, 20:31
Cheers guys
Got the clips, left the brace for now. Something much more interesting is being fitted Saturday
Leethesparky
Quote from: Essex2Visuvesi on January 18, 2019, 18:27
Lol
Quote from: Leethesparky on January 24, 2019, 20:32
Cheers guys
Ooooh.... You gonna share??
Leethesparky
Quote from: jvanzyl on January 24, 2019, 20:55
Cheers guys
Yeah when it's on [emoji6]
 Bah...
