Fraud RS200
Started by Nostromo, July 25, 2016, 09:57
Nostromo
#100
This is kind of it. There's no definitive way of building it so I expect everyone's will be different.
wozzy
#101
Have i to start adding my build to this thread when i get round to the build?
Essex2Visuvesi
#102
Quote from: "wozzy"Have i to start adding my build to this thread when i get round to the build?
or start your own
I did look at this style of wheels for mine:-
wozzy
#103
Quote from: "Essex2Visuvesi"
or start your own
They are what i'be been thinking of
i now have a 2005 6speed roadster as the base, im now looking at turbo options   s:D :D s:D
Nostromo
#104
Probably better off starting your own thread Wozzy. Just so it doesn't get confusing with people adding pictures and answering questions n that. Visuvesi, you have expensive tastes don't you pal! They will look spot on though.
Nostromo
#105
I've been a bit quiet recently. Mostly focusing on the house, very occasionally on the car.
Spent a little bit of time trimming the roof section. The top right and left corners where it meets the windscreen weren't the right angle so have cut them away and will need to fiberglass the correct shape once it starts to warm up!
Had the tyres removed from the old wheels and set about respraying two of them for the rear end. I've ordered some 40mm spacers which will hopefully be with me this week. These will bring the offset to 0 with the new body on the car. Once the spacers and wheels are on, I can set about getting the rear end properly lined up!
Primed
Sprayed
Finished
Brought my bumper to work and cut some holes for the indicators. Now, I can indicate  s:) :) s:)
I may have also set the building fire alarm off in doing so. It apparently works on dust as well as fire :bolt:
Using a couple more bits I found in my recycle bin at work (box section) these will be my brackets for the clam. They will be reinforced with some 3mm stainless plate to give the footprints a larger surface area then bolted and glued through the hardtop.
This is my hinge which will go inside the clam. The bits of box section (not in the picture) will be bolted through another piece of plate, through the hardtop then through another bit of plate underneath in a cross shape for a bit of extra rigidity.
That's where I am now and i'll probably set about doing the other couple of wheels over the next couple of days.
MR TWO
#106
Keep it up amigo...
James and his MR2
#107
Hows the project, still going strong?
Quote from: "James and his MR2"Hows the project, still going strong?
+1
Four months spent on the house is quite enough, without an update on this interesting build!  s;-) ;-) s;-)    s:bounce: :bounce: s:bounce:
Nostromo
#109
Didn't notice that anyone had written on here, sorry. Not that much has gone on recently. Still doing a lot of work to the house and having a big push for the next month at least before the new carpet is put down. If I never see another pot of paint, I'd be a happy man!
I now have four matching wheels but am waiting for my front spacers to be returned - found hat one had been cut wrong and had a 2mm difference between sides. Originally thought it was a massive buckle on the wheel!! Apart from hat, have done a little more painting around the doors and frunk. I so badly want to get out and work on it but just don't have the time at the moment  s:( :( s:(
Nostromo
#110
Photobucket not working, will try to repost the pics and uodate
The Other Stu
#111
Imgur is a good place  s;) ;) s;)
Treboeth
#112
Just add them using the img button.
 l viewtopic.php?p=257299#257299 l
Nostromo
#113
[attachment=0:1a8shhdk] ia0 20171006_172008.jpg ia0 [/attachment:1a8shhdk]
We're getting somewhere. Bought my rear window, that was expensive! Sprayed a couple of bits and fitted a nice little air filter. The car now has an odd hoooooooooooo noise on tickover.
[attachment=1:1a8shhdk] ia1 20171010_132718.jpg ia1 [/attachment:1a8shhdk]
Doing some work on the shutlines. Door and sideskirt match. Since then, the rear clam is also taking good shape. Just to note, the clam and rear edge of the skirt are on the wonk in this picture. The wheels aren't actually that far in.
[attachment=2:1a8shhdk] ia2 20170928_165935.jpg ia2 [/attachment:1a8shhdk]
It's coming together. Had a bit of a revelation that if I don't just grow some balls and start cutting bits off and making them fit, it'll never get done.
Nostromo
#114
[attachment=0:sw8lw4lu] ia0 20170919_171627.jpg ia0 [/attachment:sw8lw4lu]
Rear lights and indicators all round are now working.
Had a bit of a hit at home when someone tried to break into my garage. It's now been mega reinforced with door bolts, padlocks and a medieval door brace. Bastards.
wozzy
#115
Looking good, keep up the good work
Nostromo
So I've not been on for some time but just thought I'd show you all what I've been up to. This is a bit of a brief overview as its been a couple of years in the making now.
Window fitting and racey mirrors
Headlights were a ball-ache
Modified the roof
Sprayed and fitted
Not bad for a rattle can job
Spraying up the rear end
Fitted and lifted
Nice new exhaust
Almost finished, just a few bits to sort before the MOT now - rear fog light, rear inner wheel arches, exhaust mounts, a service
MR TWO
Thats quite a result - congratulations!
CrazySX
Looking good. Just needs dropping a few inches Now;)
Sent from my SM-G960F using Tapatalk
alancdavis
Interesting project ,,would like to do one of these
Red Calipers with DBA Cross Drilled and Grooved Discs,,,,2005 Red and Black Leather Custom Seats,,,,,TSW,17ins Wheels,,,,,2003 colour coded side vents and rear bumoer inserts,,,,Custom rear bumper skirt,,,TTE Twin Rear Pipes,,,,,,TTE Front Bumper,,,,,Red and Black Steering Wheel,,,,,Blitz Induction Kit,,,,,TTE Style Bar,,,,,Goodridge Stainless Braided Hoses,,,,,,,,,Front and Rear Strut Braces,,,,,,Rear spoiler
