Petrus and 13 Guests are viewing this topic.
Garage electrics finished!! :-D
Just received from Alan in the US.
How much and exactly where from, please?
Quote from: Carolyn on August 20, 2018, 12:34
Bought them off Spyderchat https://r.tapatalk.com/shareLink?url=https%3A%2F%2Fwww%2Espyderchat%2Ecom%2Fforums%2Fshowthread%2Ephp%3Ft%3D150903&share_tid=150903&share_fid=3075&share_type=t
FS: New Motor Mounts, Kirkosaurus Inserts, Stock Shifter, TRD Shift Knob, Cubby Lid
Paid 60 dollars for delivery. So 190 USD all in.
They came with the inserts as well so I can choose to go with them or not...
Double post
So.. Wheels back on. Battery flat though.
Took a while to find a decent earthing point for charging- for reference for others the airbox heatshield works well!
Currently waiting for 10 mins with both on fast idle, then I'll get the front up on ramps so I get the additional height clearance for when I raise the rear...
Victory!
It's up on ramps and the front bumper is off :-) tomorrow afternoon and evening I'll put the new engine on the stand and check it over and then start taking bits off of the old engine/ build the dolly, and start removing bits off the car.
 i am a little bemused.
Why pick the front up??  With the bumper off, you should be fine.
Quote from: Carolyn on August 20, 2018, 19:29
Well....I guess I'd read a few posts of people saying they could "just" clear the subframe when lifting the rear (cant remember the specific poster) so I figured this way I'd have a bit extra space and less stress and chance of damaging things...
Can't believe you're having to sell the supercharger.. :-( I'd totally have that one if I wasn't so invested with the current!
If you're leaving the subframe in, you'll be lifting it a long long way with the front up that high.
tomaky
Agree with Caroline. I'd advise taking the sub out. Lifting the rear.
Westfield Seiw
Ex - 2005 Porsche Cayman S
Ex - 2003 Sable
Ex 2004 Blue  Roadster RIP
I got a set of these many months ago and still haven't used them as I'd anticipated but I'm planning on dropping my engine out on one of them at least, possibly still attached to the subframe.
https://www.sgs-engineering.com/wd4000-450kg-wheel-dollies-set-of-four
Quote from: tomaky on August 20, 2018, 21:01
Fair enough... Well I'll try and figure out how to get that out...
tomaky
Let me know if you need any guidance. I had alot of speed dials setup when I was mucking about with the turbo 2 [emoji23] someone's always done it before :)
Westfield Seiw
Ex - 2003 Sable
Quote from: tomaky on August 20, 2018, 22:21
Yeah I shall definitely be needing guidance!
Can you pm me your number??
Tonight's first challenge- getting the new engine out of the shed and in proximity to the car!
Getting there!
Now that took WAY longer than it should have...
Ok it's all prettied up...I SHOULD really start on the swapping stuff ..
Quote from: jvanzyl on August 22, 2018, 22:17
Who said it should have taken less time?
Life is finite but many tasks don't seem to take that into account. That is the way of things. In my experience a job takes as long as it takes, particularly if you want it right first time.
I guess that you are not paying yourself by the hour, so take your time and enjoy what your doing. You have alternative wheels and I believe the summer is on the way out so where is the deadline?
Quote from: jvanzyl on August 22, 2018, 20:23
Getting there!
John, when you've finally reached Oz with it would you mind measuring the lump please? I'm sure it's noted somewhere already but I need to make provisions for where to store my various components when they're out.
I'll be rebuilding the head so that'll be off but need to plan where I'm storing the block.
Cheers!
Quote from: Call the midlife! on August 23, 2018, 12:03
Getting there!
Cheers!
FYI @Call the midlife! I saw a rebuilt head on ebay for 45 quid with no reserve.
Quote from: shnazzle on August 23, 2018, 12:41
Getting there!
Cheers!
Yeah, I get your thinking but as previously discussed I think it'll do me and the boy good to rebuild it together through the winter.
And we've only got ourselves to blame then if it blows up![emoji23]
Thanks as always though.
A £45 rebuilt head?
If it sounds too good to be true...
