'01 Silver - The daily commute smile machine!
01 Silver 1ZZ<br />The Smile Machine: viewtopic.php?f=88&t=59837
@jvanzyl  :'(
I feel for you. Well worth doing what you have done.
If not, in time the car would have stunk.
Chap at work, spilt some in his work van. Oh its only the work van so left it. Mistake.
Back on the turbo thread:
What I have so far..
  • Turbo- GT2554R
  • Turbo manifold
  • Oil & Water lines
  • Charge cooler pump
  • Charge cooler bracket
  • plug thingy for charge cooler pump
  • 4x6 charge cooler cooler
  • Cinquento radiator
new normal radiator
  • Emanage ultimate (EMU)
  • Innovate wideband sensor
  • pressure sensor for EMU
  • afr wiring for EMU
  • 2zz yellow injectors
  • 3" flexi
  • v band clamps x2
  • 200 cell cat
Still to buy:
  • muffler
  • various mandrel bends all in 3"
  • AFR gauge
  • Charge coolant overflow/filler bottle
  • Silicone piping for charge cooler air
  • Lots of o clamp things
  • Cone filter for turbo / or hookup to AEM cold air in take...
  • Pipes to run to charge cooler radiator in front
  • Blow off valve (need to figure out when to put it)
No idea what else I need..
Boost and oil pressure/temp gauges, boost control solenoid and associated sensors/adapters for the gauges.
AEM gauges come with sensors and looms but be warned, the looms aren't long enough for mid engined use...
Quote from: Call the midlife! on November 14, 2022, 15:31Boost and oil pressure/temp gauges, boost control solenoid and associated sensors/adapters for the gauges.
Excellent thank you!
I've got the oil pressure and temp gauges already. Pressure sensor just arrived today for the emanage..
So the still to buy list is now:
  • boost gauge
  • muffler
  • AFR gauge
  • Clutch (suggestions welcome)
  • vacuum block?
  • BK6RE spark plugs
  • Aluminium pipe for cooling setup
  • boost controller?
Have you got it on the engine yet to know which way around the turbo is going to sit? If not then I'd wait until you're sure of the orientation before getting anymore parts in.
Quote from: Call the midlife! on November 15, 2022, 06:48Have you got it on the engine yet to know which way around the turbo is going to sit? If not then I'd wait until you're sure of the orientation before getting anymore parts in.
Did a mock up a while back, but hadn't clocked the turbo yet so that I could put the intake on the left side.. took some very basic measurements..
However as per the other "rust" thread.. I've got some stuff to take care of prior to getting back onto this one..
So... In an effort to save money, I took the milk home from work as no one would be there for the next week to drink it.
It then poured out in the car and I washed the carpet and cleaned below (still might need more cleaning in the tub as I can smell something..)
I then found a rust spot and made a hole through the tub, and in the process got some rust flecks in my eye as I casually blew away some of the dust.. then had 3 days in and out of hospital trying to get these removed.
Which leads me to the current progress, of this little chapter. I'm going to opt for the rubber bung idea to start with.
The below are the tidied up hole using a step drill and treating the area with kurust.
J88TEO
Quote from: jvanzyl on November 23, 2022, 12:51I then found a rust spot and made a hole through the tub, and in the process got some rust flecks in my eye as I casually blew away some of the dust.. then had 3 days in and out of hospital trying to get these removed.
Nasty little bits...had one in my left eye that caused infection - couldn't open my eyes and has to go to the eye clinic to get it out!
Quote from: J88TEO on November 23, 2022, 13:06Nasty little bits...had one in my left eye that caused infection - couldn't open my eyes and has to go to the eye clinic to get it out!
Yeah I was so annoyed at my self.. just thought I'd tidy stuff up and bam!
Gaz2405
Only just spotted that your turbo'ing this great work.
Not sure you'll need 3", 2.5" should suffice and be a little quieter.
Quote from: Gaz2405 on November 23, 2022, 14:56Only just spotted that your turbo'ing this great work.
Ah... well I've bought lots of stuff to fit 3", and I was going on the advice from Kevin at Zero rockstars
Exhausts.. I'm happy to run bigger muffler in the end..
Thought I'd put the layer of zinc primer on.. topside is fine from the kurust, the bottom side needed another coat. Hopefully later on today I can put the zinc primer on the under side. Then I'll spray on some colour and then some under body seal and finally plug it! And THEN put the carpet back in!
I wish I could make the stupid phone use the flash whenever I want.. flipping annoying
So paint has dried. Popped the bung in and then put on some under seal.
Might still put some silicone on the top side just in case.
In other news I think I may have bought @Micktet999  turbo kits manifold.. not yet confirmed it's his, but figured this would be a better option than the current one.
My mind is going to the oil drain into the sump and wondering if one of those fancy moroso sumps are worth it vs making an angled drain into the existing sump.
If it's a Turbokits cast manifold then it'll probably put your turbo the opposite way around to how you have it now, just bear that in mind.👍🏻
The Morosso/Eliseparts sumps are as much for the extra oil capacity as anything else, the Eliseparts return fitting could be bigger to be fair.
Exhaust brackets and rubbers arrived.
Found some brackets that are adjustable.
