Blue 03 Marty
Started by Newbie57, August 25, 2016, 16:13
Newbie57
This is it as bought 88k miles. Plenty of service history up to 2014 (84k miles). Then a bill of sale service at 87k from some dealer, filter & oil i guess.
It has a Remus twin pipe already fitted
Done so far
Fitted the strap thing on the hood ( Supprisingly still loose in the storrage copartment when I got it)
Replaced wiper motor
Replaced Aerial (needs doing again)
Replaced plugs. These were completely shot
Ouch those sparks were indeed due replacement.
Give the MAF a clean as well and reset the Ecu.
Newbie57
Arriving soon
Oil change
Air filter change
MAF clean
Alarm move
Chilli Girl
She looks gorgeous, nice paint colour too! Sure you will have many fun miles, brilliant cars and well worth keeping up with the maintenance
Newbie57
Bit of progress over the week end.
Air filter change. This has been in a long time. Last service by MrT was at 84k miles, I'm now at 90K.
Cleaned the MAF
ECU reset
Polished the lights
Before
After
Went for a spin
Took the back roads to Skinfirth, one of my favorite bike routes. Plenty of twisty B roads. Gave her a good thrashing.
Newbie57
Relocated the alarm and flipped the spare wheel at the weekend. I still have a problem with the sheared spare wheel bolt, this looks like a drill out job now. s:( :( s:(
Frunk cover now has all its plastic fasteners, £2.99 well spent.
Whilst I was in the front took a look at the general state. The external tube of the steering rack looks corroded, boots are ok. UJ looks ok apart from peeling paint. Anti roll bar coating is peeling off. Tin of hammerite is in order I think.
wafers
I do like the fl blue metallic. What's it's proper Mr T name? I'd definitely be looking for one that colour if I didn't have my fl sable  s;) ;) s;)
As for frunk plastic fasteners, where did you source  them from? Could do with some myself...
Newbie57
Vehicleclips.co.uk very quick service
Colour spectra blue mica (8m6)
Newbie57
Flush & oil change done without removing the under trays. Fitted K & N race oil filter. Quick spin tonight. Seems to run much better but maybe that's my imagination.
Newbie57
Looks like the tensioner o ring needs doing
Cross member looks ok
Agreed
wafers
Quote from: "Newbie57"Vehicleclips.co.uk very quick service
Cheers   s8) 8) s8)
Newbie57
Did the timing chain tensioner o ring today and put a new radiator from cool parts in as I noticed the old one was leaking from the lower right corner
Bit of a mess. Will drain the system and refill now
stu h
cheers for that you have spurred me on to do mine i was unsure what it was until i seen your photo  s:mrgreen: :mrgreen: s:mrgreen:
Newbie57
Radiator is in and filled. Heater works  s:) :) s:) . I swapped over the bleed and drain plugs as the Toyota ones are easier to use. Word of warning. The bleed plug did not seal properly. I probably should have at least replaced the o ring. Anyway changed it back to the coolparts one and all is ok. Will keep An eye on the drain plug to make sure it doesn't have the same problem. Only other issue was one of the captive nuts that hold the fan assembly on was missing from the new rad but I just rescued one out of the old rad.
Fog lights next
Newbie57
Got the the front bumper off tonight. Just one snapped bolt underneath. Only problem is the spares I got aren't a pair  s:( :( s:(
Tempted to try the cheap LED halo lights but I don't fancy doing the wiring, Any guide to this around?
Newbie57
Got some halo lights just trying to work out how to fit them. I think if I turn the supplied bracket at 90 degrees to the light and make a plate I can clamp them to the bumper without modifying it. Wiring was abortive today as I bought a female 9600 plug and not the male required. Off to the Stafford classic bike show tomorrow so probably get the connector there.
Newbie57
Fogs fitted now. Pretty way with a couple of 6mm screws and modified washers. Bit of wiring to do
Newbie57
After 2 years of ownership the oil consumption got to me. I had a continual P0420 code but there seemed little point in replacing the cat without doing something about the engine.
The guy I bought this off must have known there was an issue. When I went through the service history I did find a Toyota main dealer comment that the car had no oil in it at a service.
Call to Dean at Rutland located a 30k engine. So new heart, clutch rear discs and pads and no EML
delhusband
Quote from: Newbie57 on May 11, 2018, 23:01
Nice, new lease of life :)
Hate pointy animals
Newbie57
So, about 1k miles later zero oil usage.😄
