PFL Turbo - Tuned By Gibbons
Started by Essex2Visuvesi, September 30, 2016, 00:43
Essex2Visuvesi
So I have one of these:-
A great car and is good fun but could do with a bit more oomph
1st idea was to fit one of these
But finding a suitable gearbox proved to be a fruitless exercise so I started thinking about a V6 swap.
Then this turned up on ebay
 m http://www.ebay.co.uk/itm/182275138565 m
Some beverage tokens changed hands and its now in my shed  s:) :) s:)
The manifold shows signs of a previous repairs by untrained marmosets
this has been handed to my tame fabricator who will either repair or make a new one.
The turbo has been tested and spins up nicely on compressed air with no leaks. No play in the shaft either.
The turbo is missing the actuator, but I have managed to source a replacement.
The kit also comes with an e-manage blue (frustratingly I just sold an Apexi PFC last month   s:evil: :evil: s:evil:  ) but has the cables and software so I'll run with it for now
A beast of a dump valve
Not sure if I'll keep this as I do prefer the sound of wastegate chatter
Also in the package was the wiring loom, boost sensor, some hoses and a few other bits.
I've ordered in a few extra bit to improve reliability.
    Mishimoto Radiator
    Oil cooler kit with auxilary oil pressure and temp gauges
    Boost gauge (tho I did realise that buying a mechanical one was foolish as I'll need to run a pipe through the cabin   s:oops: :oops: s:oops:  )
Further mods will include a barrel type charge cooler to keep the pipework nice and short
Next step will be to do a head leak check, and compression test before I start the fitting process
What's the waste gate setting going to be?
Essex2Visuvesi
0.5 Bar or 7.35Psi from the factory, however it can be changed by changing the sping, so I have also ordered a 0.3 and a 0.8
Will be starting off with a 0.3 and work up from there
This is the Actuator
 m http://shopping.kinugawaturbo.com/kinug ... ation.aspx m
iower
So no need for a boost controller, just run wastegate pressure as dictated by the spring? Sounds like a simple way to do things, as long as you keep an eye on boost with a guage (which you have mentioned)
iower
Also, "untrained marmosets" had me sniggering
The Other Stu
Quote from: "iower"Also, "untrained marmosets" had me sniggering
I've seen the state of the repair and I still laughed.
No Longer Here
The .3 should be spot on for what your looking for.
Essex2Visuvesi
Head gasket leak test was successful  s:) :) s:)
after 15mins of Idle, no bubbles or colour change   s:bounce: :bounce: s:bounce:
The same cannot be said for my Alfa 147  s:( :( s:(  decided to test that as well and it seems I have gas in my coolant   s:evil: :evil: s:evil:
Essex2Visuvesi
Parts arriving on a daily Basis  s:) :) s:)
We now have:-
Manifold & Turbo wrap
Reading the articles there seems to be a lot of heat so decided these would be prudent
Oil Cooler Kit
Overkill? perhaps, but better to be safe than sorry and the sandwich plate gives me the feeds for my oil pressure & temp gauges
Apexi Air Filter
Genuine not a copy.  The one in the kit was bent and well loved and I do like the Apexi filters
Braided Oil return line & Hose Finishers
Bit of bling never hurts, and the feed is braided so might as well make them match
New Sump
Makes the fitting of the oil drain easier and the old one will be retained so if it all goes Pete Tong I can go back to N/A
Timing chain tensioner
The seal on mine is leaking a bit so decided to replace the whole thing
Just waiting for the Turbo Manifold to be returned from the fabricator and I can get started
Essex2Visuvesi
Oh yes.... and one more thing....
Someone posted on here about Joining the 2 O2 sensors together so both the left and right banks are connected to one sensor, Cant find it tho
I want to do this as the Turbo downpipe has 2 sensor holes and I want to utilise one for a Wideband sensor
Need to be linked regardless. You need to link both signal wires, white from memory.
Essex2Visuvesi
So basically I just need to make up a Y adaptor lead with all wires joined
2 sockets to the the loom for Bank A/B and one plug to the O2 sensor?
Yep
Which sandwich plate mate from where and how much?
Oil cooler is on my list too.
Essex2Visuvesi
Quote from: "1979scotte"Which sandwich plate mate from where and how much?
this one:-
 m http://www.ebay.co.uk/itm/152148252270 m
Have to say for the money it looks pretty good
Will be testing parts prior to fitting
Just need to figure out where to fit it
Do you think its ok it not being thermostatic?
I supose it just takes it a little longer to warm the oil.
Essex2Visuvesi
I did think about that, and I may well change the sandwich plate to a thermostatic one at a later date.
its quite a small so I'm thinking it should be OK.  Had I gone for a larger one then I would have gone for a thermostatic one, but that then gives a further headache of location.
After thinking about it i will probably go for the exact same cooler but with the thermostatic sandwich plate wasnt much more expensive.
 m http://m.ebay.co.uk/itm/7-Row-Universal ... nav=SEARCH m
Essex2Visuvesi
I looked at that one (or at least a similar one)
I cant recommend one yet as I haven't fitted it so it could leak from every joint lol, but the quality seems there. There are no tool chatter marks on the sandwich plate (often found on cheaper machined parts) and so it looks  like its been through some kind of rudimentary QC.
Essex2Visuvesi
Double post
Essex2Visuvesi
Picked up a couple of these today from my local motorparts store:-
Only a fiver each so thought a brace of those in the turbo intake and we'll be pushing 400Hp   s:scared: :scared: s:scared:
Then the creative juices stated flowing, so I apologised to the shopkeeper and left.
Now the slightly more serious bit.
maintaining engine bay temps are a challenge when it comes to turbocharging, moreso when its mid engines, so I got to thinking... extractor fans... run these on a thermostatic switch to extract hot air from the engine bay using some 3" ducting
probably a daft idea but I'm not one to pass up a bargain   s:roll: :roll: s:roll:
I would say air in over air out but the idea has merit
Essex2Visuvesi
Quote from: "rbuckingham"I would say air in over air out but the idea has merit
Fair point, I did think that as well
Maybe one sucking air in to the engine bay, and the other blowing air out
Quote from: "Essex2Visuvesi"
Suck air in via the engine lid vents.
Air flowing under the car sucks it out.
For the SW20, but food for thought nonetheless:  m https://twosrus.com/catalog/product_inf ... ucts_id=96 m
