2zz on Ebay
Started by keeper2611, October 12, 2016, 23:04
keeper2611
Seems reasonable at the moment if anybody wants a project
 m http://www.ebay.co.uk/itm/toyota-mr2-ro ... SwpLNX~KPb m
2002 Red pfl being slowly modified
If its cheap enough i suppose but somtimes puting someones failed project to right is harder than starting fresh.
Good heads up btw.
I got in touch with the owner.
He said the conversion was done by Lee at se7en, and that headcase did the tuning....
The Other Stu
He clearly doesn't really want to sell it.
Absolutely no info on the car - does it drive properly?
It's got nearly a whole years MOT on it.
I don't get it. Why would you not fully explain everything you've done to the car? If it's as good as it sounds, it's worth a fair bit. It'll end up going for £1k if he's lucky right now.
In my opinion, selling a car by auction on eBay is a bit hit and miss too. You often get people who win, turn up, then decide that it's not as described (You never mentioned the scratch on the front window or the cracked fog light) and then it becomes your word against theirs.
No Longer Here
The guy did say that he's on the forum but has not logged in for a while - I'll try and get his handle from him and then we can maybe do some snooping!  :-) :-) :-)
MOT and tax run out in August 2017 apparently...
headcase
Well I am bidding on it I have it yes I know the car I had to sort wiring out  and couple other bits
Sent from my ASUS_T00G using Tapatalk
If that's not going to send the bidding through the roof then I don't know what will!
headcase
Last time I saw it . The paint was bad and some dents but some panels and a bit tlc it come back it drove ok . But must been about a 1yr ago when I saw it
