Are these worth the effort.....
Started by wotugonado, March 8, 2018, 18:12
wotugonado
So got these off eBay a while back, I know they're not a complete set but I can use the matching pair
they need a clean up, and the rubber seems to have split
My questions are,
can the rubber be replaced?
Are they useable as they are?
Which ones do they replace?
Or are they for the scrap bin?
s12vea
I can't see the pictures on my iPad just two small white squares
TF204 Blue
Another one won't hurt  .....
Brizee67
I can see the images on my iPhone no problem
wotugonado
Weird! The pics seem ok to me too. Any one else not seeing them?
Pics are fine.
Arms look like they have seen better days.
I would only use the matching pair.
Lower trailing arms I think.
Top speed
http://topspeedauto.com/toyota-mr2-mrs-spyder-2000-2005-adjustable-rear-lower-trailing-arm/
wotugonado
Quote from: 1979scotte on March  8, 2018, 20:05
Pics are fine.
Top speed
Cheers, yeah I'd only use the matching pair of arms, but I can strip the others for spare bits.
Nice! if they're worth that much (I got them for next to nothing) i might persevere with them. Anyone have a rough idea of powder coating costs for the top 2 arms in the pic above ?
I see on the topspeed pics they don't have the rubber, can they be run without them
8thumpers
Quote from: wotugonado on March  8, 2018, 20:47
Pics are fine.
Top speed
Topspeed arms have spherical joints which are different to your bushed arms. You def need poly or rubber bushes in yours.
s12vea
I'm using safari not the Tapatalk will check Tapatalk
TF204 Blue
s12vea
Tapatalk shows them, but safari doesn't how strange.
TF204 Blue
wotugonado
Quote from: s12vea on March  8, 2018, 21:51
Wonder why that is, they're hosted through imgur if that makes a difference.
wotugonado
So I sacrificed one to have a better look. The rubber appears to be bonded to the arm, basically disintegrated when I pulled on it. The outer metal sections  pulled out and  Inside there's a movable joint held in by circlips. I'd need to remove this before powder coating, can't see how I'd get it out though even with the circlips removed.
s12vea
Quote from: wotugonado on March  8, 2018, 21:58
Strange how on iPad safari can't view but on tapatalk no issues
TF204 Blue
8thumpers
Quote from: wotugonado on March  8, 2018, 22:23
Are they machine pressed in/out?
wotugonado
Could well be the case. If they are I think I'll just unscrew the ball joint end and hammerite them and just get the fork section and main body powdercoated.......
8thumpers
Quote from: wotugonado on March  9, 2018, 22:43
Could well be the case. If they are I think I'll just unscrew the ends and hammerite them and just get the fork section powdercoated.......
The rubbers are just dust covers then? In which case they are spherical joints I'm guessing - you may be able to get new dust covers for minimal cost.
wotugonado
It does look like they are, I found some rubber grommets online that look like they could well do the job of dust covers, I'll probably have a play round with the dismantled one and see how I get on.
