Engine steady/damper
Started by Carolyn, March 30, 2019, 10:55
I bought one of these dampers when you first mentioned them but havent worked out where to fit it so will be interested what you suggest when you see Scotts car as to a suitable mounting as I would up for a V6 version too.
Quote from: Topdownman on April  5, 2019, 15:23
Problem is one V6 isn't the same as another.
Yours, mine and @MR TWO are all a different flavour.
Mikeymead
I'd be interested in a set please.
Amarlborough
Ill take a set if you make any more Carolyn
All of you who've expressed interest, need to PM me with your mailing address and email address, so I can send installation guide.
Progress is being made!
Link for the damper.  It comes in a few colours, so if you search Ebay for 'Engine Damper' you can pick that which you fancy.
Ignore which car they are for.  They come in long and short.
You want short.
https://www.ebay.co.uk/itm/Engine-Torque-Damper-172mm-196mm-For-Toyota-Celica-Starlet-Supra-Turbo-Blue/113082519868?epid=5004684772&hash=item1a543e513c:g:~0sAAOSwuzRXf38F
Great stuff! Ordered.....
Sweet. Cheeky red one on the way, will look lovely with the blue accents..[emoji851]
Quote from: Call the midlife! on April  9, 2019, 11:00
@Topdownman
He's just sick isn't he
Quote from: 1979scotte on April  9, 2019, 11:57
@Topdownman
Hahahahaha! "Different "..
It seems (from corresponding with Petrus) that these are stiffer than they used to be.
Mine's a couple of years old now.
Don't worry about the stroke, just adjust for length and install.
Quote from: Call the midlife! on April  9, 2019, 12:25
@Topdownman
Words fail me.....
Quote from: Topdownman on April  9, 2019, 14:00
@Topdownman
Words fail me.....
Fitting it to a knackered engine so it might as well look pretty![emoji38]
Looking forward to the fitting kit and bolt it in  :D
For anyone who would like the PU bushings a slightly softer; drilling a few holes trough them axially will do that trick. This gives the material space to deform instead of only compress.
Please. everyone, just adjust the length and install it!
They will 'run in' as they're used.
More importantly:  Deal with sloppy fore and aft engine mounts first, (if your ARE sloppy),
Mikeymead
Received my kit this morning, many thanks.
Just checked the colour of my damper.
I may be in for some stick.....
Quote from: Topdownman on April 10, 2019, 20:57
That gold though, tis a thing of beauty!
Received my kit today, lovely stuff, cheers!
delhusband
Bahahaaa! John, check it out...
Hate pointy animals
Quote from: delhusband on April 10, 2019, 22:41
You know me Derek, I'm very much live and let live, if Simon has decided to embrace the rainbow I'm all for it![emoji23]
You will all see that one of the rose joints (the one with the locking nut) can be adjusted for length.
Make sure there is still a decent amount of thread attached to the damper.  Otherwise it might tear itself out.
If you need a bit more length, slacken off the ally collar and wind out the ally threaded part to make up the length.
Hopefully I've assembled this right- should be midway on the stroke.
Looking forward to this little bit of bling bring put in place!
Quote from: jvanzyl on April 11, 2019, 10:26
Not quite:  Invert the bolt on the right.  The spacer is correct once the whole thing is inverted.  Bolt head underneath, spacer on top with the narrow part going into the hole on the head.
