Exhaust change
Started by Zxrob, December 1, 2019, 18:33
Zxrob
Evening all
I changed the exhaust out today, nothing wrong with the original system, just sounded naff, picked a decat one up for good money, cleaned it up and installed it today, the car now sounds like a little sports car :)
One thing I was expecting was the EML to show up on the dash, let it up warm up and and revved it a bit but no light came on, surprised, it it a case it will come on when I take it out and give it a bit of stick
I have ordered a resistor to wire in although its not turned up yet
Rob
Adventure before dementia 😁
What backbox is that?
Zxrob
Quote from: Zxrob on December  1, 2019, 18:48
Quote from: shnazzle on December  1, 2019, 18:46What backbox is that?
Proflow
Rob
Custom made then. I imagine it's quite loud with just a little box and no cat
Zxrob
Quote from: shnazzle on December  1, 2019, 18:55Custom made then. I imagine it's quite loud with just a little box and no cat
Yep, its quite loud without being silly, fitted quite easy too, well apart from getting those bloody rubber mounts off ::)
Rob
Quote from: Zxrob on December  1, 2019, 18:33it will come on when I take it out and give it a bit of stick
Yes.
You need an extension plug. Works a treat.
Do share a sound track!!
Zxrob
Quote from: Petrus on December  1, 2019, 19:07
Yes.
Enlighten me
I was just going to wire in a resistor to "fool" the ECU, or could I just clear the code with a OBD
Rob
Quote from: Zxrob on December  1, 2019, 19:17I was just going to wire in a resistor to "fool" the ECU, or could I just clear the code with a OBD
Rob
The resistor is less ´just´ than the extension.
Yes, after fitting a device, the code can easily be cleared. Just disconnecting battery plus for 10 minutes works too.
m1tch
Guessing you are swapping the cat back in for the MOT or any roadside checks?
Zxrob
Quote from: m1tch on December  3, 2019, 07:26Guessing you are swapping the cat back in for the MOT or any roadside checks?
Thats the game plan ;)
Rob
