Supercharge HQ.
Started by Carolyn, October 1, 2020, 15:10
The yellow beast has arrived.
Now we have two supercharged MR2s on the premises, alongside a rather special MR S.
What fun.
loads of work to do on Scotte's, but nothing tooo daunting.
Youve got a roots and a centrifugal just need a whipple to complete the set.
Quote from: 1979scotte on October  1, 2020, 15:17Youve got a roots and a centrifugal just need a whipple to complete the set.
Well, now the mystery (for me) is solved. I should have guessed. Be careful though, because when it's fixed it will go like a rocket!
Quote from: Joesson on October  1, 2020, 15:48
It really wasn't a secret Tony.You cannot view this attachment.
Needs an arrival pic too
Quote from: 1979scotte on October  1, 2020, 19:59
Cool that you arranged for a matching trailer!
Quote from: Joesson on October  1, 2020, 15:48Be careful though, because when it's fixed it will go like a rocket!
C'mon; it's not like a rocket scientist is working on it. Oh!, hang on; that's exactly who's casting her micron level of attention trained eye on it.
Is it finished yet?
Quote from: Carolyn on October  1, 2020, 15:10The yellow beast has arrived.
What fun.
I, for one, feel Bee is in the best hands. 👍👍
Chilli Girl
Right now - five roadsters on the premises.  Nuts!
The yellow beast, the blue S/C car, My MR S, Jon's PFL Roadster, and the blue TF.
Quote from: Carolyn on October  3, 2020, 16:52Right now - five roadsters on the premises.  Nuts!
One more only allowed, and that's only if they are socially distanced!
Does this technically class as a meet? 😂😂
househead
Quote from: StuC on October  4, 2020, 17:50
Just needs one more for a complete rule-of-six set!
Edit: just seen Tony beat me to that one.
Quote from: househead on October  4, 2020, 23:07
Beaten to the punch by an OAP.
Experience beats youth once again.
Quote from: 1979scotte on October  5, 2020, 06:41
In other news:
The seven dwarfs have been advised that they can now only meet in groups of six.
One of them isn't Happy.
Scotte's yellow beast now has a new clutch-slave-cylinder- from -hell, thanks to Jonbill spending most of the day working on it.
That was the last job on the list - yee hah!
Quote from: Carolyn on November  7, 2020, 15:23Scotte's yellow beast now has a new clutch-slave-cylinder- from -hell, thanks to Jonbill spending most of the day working on it.
Well done both. @Carolyn @jonbill
Great club spirit. 👍👍
Well done to all concerned!
Many thanks to @Carolyn David and @jonbill
jonbill
Quote from: 1979scotte on November  7, 2020, 17:00Many thanks to @Carolyn David and @jonbill
My pleasure. Scotte - do you have the "project" for the ECU by any chance? I'm looking at checking out the map and changing it if necessary. I don't fancy starting from scratch, so a copy of the "windows client" project would be dead handy.
Quote from: jonbill on November  7, 2020, 19:34
Sorry mate I've only plugged the laptop into it once to check afr and boost.
All I've done is downloaded the software from the website as far as I remember.
I'm sure I saved a copy of the map when I did that but it probably got deleted since due to lack of storage.
@jonbill
Unless this is relevant
jonbill
Quote from: 1979scotte on November  7, 2020, 20:06@jonbill
yes! a zip of that EMU folder would be handy.
you didn't do the original mapping I take it? was this "bee6" folder created when you plugged in your PC to check AFR and boost?
did it give you an option to use the map on the ecu or the one in the project when you plugged it in?
Quote from: jonbill on November  7, 2020, 20:15
Pretty sure it gives you the option to backup the map on the ecu to your pc.
I'm hopeful that the majority of the map is good and perhaps only needs tweeking at full boost/revs.
The ecu has auto tune and target afr so I would like to think it will adjust itself to suit.
Last time it saw a dyno it made 255 ft lbs ish at the wheels the worry would be if it makes much more torque it could break a drive shaft or maybe bend a rod.
