Flywheel cover
Started by Petrus, September 5, 2022, 15:25
The bell housing a bit different, the bottom half of the clutch housing is coverer by a metal sheet
any reason why not to have it off?
It's a snap-in plastic cover.
Got a spare somewhere...
So no weight gain there, not really necessary cooling and some risk of dirt getting in.
Subject covered. Literally.
Quote from: Petrus on September  5, 2022, 15:25The bell housing a bit different, the bottom half of the clutch housing is coverer by a metal sheet
Another example of the general lack of rust on the underside of your car. For instance the horizontal , silver, tie bar. Mine is the same colour but only because I derusted and repainted it.
Conversely I note the starter ring gear is very red! Lack of recent use?
Quote from: Joesson on September  7, 2022, 09:06Another example of the general lack of rust on the underside of your car.
Not mine  :-[
Mine has less rust still and an as new lighweight flywheel.
It was just a thing I wondered about. Restless inquisitive mind  O:-)
